timing chain q?
Old Sep 26, 2011 | 02:13 PM
blacksss's Avatar
timing chain q?
i have about 58k on my car right now and i think my timing chain tensioner is going bad. do you recommend that i replace the chain and the tensioner or just the tensioner?
Old Sep 26, 2011 | 06:50 PM
insylem's Avatar
I think just the Tensioner. There is an upgraded one you can get.
Old Sep 26, 2011 | 08:24 PM
blacksss's Avatar
do you by chance know how many miles the chain is rated to last?
Old Sep 26, 2011 | 10:01 PM
Coblasts's Avatar
Just replace the tensioner,its a easy job or the dealer will charge you .5 of an hour.
Timing chain should last the life of the engine as far as Im concerned and doesnt requore replacing unless here is something wrong with it
Late models (2006)had bad chain rollers and there was a tsb out on that.
Old Sep 26, 2011 | 11:39 PM
blacksss's Avatar
whats a tsb, i have an 06. Thanks for all the help by the way!
Old Sep 27, 2011 | 07:20 AM
Coblasts's Avatar
Is your car making noise all the time from the cam chain?
Just had mine replaced(tensioner) but I was getting it intermittenly on start ups once and a while and it seems to have solved the problem.
Its a inexpensive part and would change it firsts.
I will look up the tsb when I get time.And its a technical service bullitine
Old Sep 27, 2011 | 11:57 AM
blacksss's Avatar
same **** thats happening with mine, hear a little chain noise on startup then it dies down. Just dont want to cause any probs.
Old Oct 1, 2011 | 05:04 PM
blacksss's Avatar
last question, is this the latest and greatest tensioner?
Ecotec Timing Chain Tensioner 12608580 - Crate Engine Depot
Old Oct 1, 2011 | 05:18 PM
Coblasts's Avatar
Not sure call the dealer part dept and ask ,there was at least 3 revisions !
Old Oct 1, 2011 | 07:54 PM
guitarenvy's Avatar
Let me know what happens after you replace that tensioner. It will be interesting.
Old Oct 2, 2011 | 03:33 PM
blacksss's Avatar
what do you mean it will be interesting?
Old Oct 2, 2011 | 04:33 PM
guitarenvy's Avatar
It takes more than half hour like previous poster said. Its not just remove and install. You will have to take the valve cover off or you wont be able to set the tensioner up = mass engine destruction. Also when you remove the tensioner your chain slack that will hang on the crank gear resulting in 1 tooth out of time, engine light on and having to now take the engine front cover off to retime it. Just saying, be prepared you gotta know what your doing. There is a new design tensioner without an oring, it is low clearance fit.
Old Oct 2, 2011 | 08:44 PM
blacksss's Avatar
ive read a couple posts saying that the new one just bolts in and your good to go, if i have to mess with timing and all that im not even going to put my hands on it lol.
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
