Tire Pressure Monitors??
Hey,
I recently installed an amp for a sub. In order to do so, I had to remove the battery cables. After the installation, I noticed that my Tire Pressure Monitors were claiming that I had 0 PSI in my left side tires, and only 20 PSI in my right side tires. After about an hour of driving they came up to around 26 PSI. I know that I have 33 PSI in all four tires but the TPM keeps claiming that there is only 25 - 26 PSI. Is there a way to reset the TPMs? Thanks!
Jake
Jake
all you need to do is set your air at about 40 psi and then hold the lock and unlock on your key fob till the horn sounds then go to the left frt and start letting out air till the horn churps and then to the right and so on till your all done
DANRICKARD
Oct 1, 2015 12:08 AM
