Tire rubbing seriously bad.
Hey guys i had a serious issue with my front right tire, inside tread/sidewall rubbed almost to the belts only in a patch of the tire, so intermittent rubbing issue.
Never noticed until i sold my enkeis this past week and removed them to sell. The tire size was 235.
Background: tires were fine that i can remember a couple weeks ago when i removed them to check suspension. I then proceeded to take my car into the shop for front control arm bushings and new powergrid end links. Shop did not mention tire damage. After the car came back, i of course wanted to test out my upgraded suspension. I took some high speed left hand turns resulting in a lot of understeer.
Now i have new OZ 17x8s with Michelin 225s and am checking after every drive for tire or wheel damage from rubbing. None i can see as of yet. I also have NOT pushed any hard turns since for fear of damaging my new set up.
Clearance by the strut assembly and top end link bolt are very tight. I think i should consider a spacer to prevent any potential rubbing.
I believe in the high speed turn the sway bar link top bolt got pushed out into the previous tire. Maybe the spring seat rubbed it during the turn, though i dont think the suspension geometry would allow that to happen.
Any input or experience would be greatly appreciated.
I will post pictures of inner clearance tomorrow.
FL
FL
Zo6balt (03-01-2021)
Oz Alleggerita 17x8 40mm
Again, the enkeis were on for 2 years with zero issue. I rotated them many times and not once saw any tire damage or deformation.
i had my daily commute today, checked at my shop and when i got home, no visible wear or damage. I did drive more aggressively to see if it pushes something onto wheels.
The top bolt of endlink and spring seat are all fixed to the strut assembly so i doubt anything there touched the tire but that is the only place where it seems to be very close? Springs look fine, control are looks visually sound. I have no idea.
i am going to have an alignment done Saturday. Maybe they can give me some input.
i am going to park at an angle with the wheel turned in and a board under the right wheel to try simulate the angle that turn was taken, maybe it pushed it in way where something rubbed.
Strange, I ran 235/40-18R on Enkei M52 and did some pretty aggressive mountain driving, no understeer, but pushing things right up to the grip limit and had no tire rubbing. I wonder if something got caught between the tire sidewall and a suspension part
Could have happened like that, something odd happened that's all i know. I think even the shop i took it to messed something up?! I hope not..
hmmm a mystery.
After the alignment, i will just keep a daily eye on my new tires.. i just don't want anything to happen to my Michelins lol best all season tire I've ever driven on.
hmmm a mystery.
