Tranny clunk and shifter binding
Old Apr 1, 2014 | 08:56 AM
Carramrod's Avatar
Hello everyone. A month ago I purchased an 09 SS with 39,XXX miles on it and unfortunately I'm already having an issue with it. It actually started the day that I bought the car, but I've read about these cars having sloppy/clunky transmissions, so I didn't think much of it. Whenever On occasion when I'm starting in neutral, with the clutch pedal fully depressed, I get a slight, faint clunk when putting the car into first. I also sometimes hear the sound whenever I put my foot back on the gas while the car is in gear and moving. Another thing is that whenever the car is going up a hill, or under a semi hard pull, the shifter seems like it's binding, but then springs into the next gear. I'm fairly certain that the first problem is the clutch, and I'm wondering if the second could be a bad motor or tranny mount thats causing it to bind up the way it is. Has anyone else had a problem similar to this? I bought the car as a "certified" pre-owned from a Chevy dealership, so if it happened to be the clutch, would they warranty it? Thanks.
Old Apr 1, 2014 | 09:13 AM
user 72239's Avatar
Welcome to CSS!
First off, all the F35 transmissions do that. At least both my 2006 SS Supercharged and my 2008 SS Turbocharged clunk when going into first.
Old Apr 1, 2014 | 09:17 AM
buildmeanempire's Avatar
Yep. All the transmissions I've had in mine have done it. Even the one in right now that has less than 3,000 miles on it.
Old Apr 1, 2014 | 10:22 PM
coyn11's Avatar
bind as in not "pop" into gears?
biniecki
Oct 25, 2015 02:23 PM
OrangeCoba
Oct 1, 2015 10:00 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
