Trashed rear rotors
Trashed rear rotors
I've read some threads on here that the 08s and 09s have been having problems with the rear rotors. I even read the thread with the TSB on it. The past couple of days I've been noticing that the rear brakes were getting louder by the day....almost like I was driving with my ebrake on. So I took it to the dealer today and this is what they found on the inside of the rotor:
Notice the f-ed up brake pad and the deep cuts in the rotor....Sorry that the pic isn't the best...I took it with my iphone. So the dealer is covering this and put me in a rental. Hope fully it will be done tomorrow.
They give you any idea why? Bad pads, bad batch of rotors, assembly line problem, anything?
Hope that you at least got a decent rental, not an Aveo or something
And they gave me a Malibu for a rental.....it smells like an ash tray...but it's better than nothing!
YES I HAD THAT PROBLEM!!!!!!!!!! ******* mechanic told me that it was "abuse" i had 6000 miles on it at that point, more than 4000 was highway...... fixed under warranty
my pads were not gone, just deteriorating bad
Say, were the rears brakes sounding odd? Maybe seeing that pic has made me paranoid but I get a real low groaning noise from the rears, worse when bscking up and braking. Not near as bad when warm but quite loud when cold (-8 c this am) Rotors look ok so far but the way my luck goes.....
Malibu.....not a bad ride. One of my co workers just bought one a couple months ago, full load, fire mist red......even has a 2.4 lol
Ford would say "that's normal". I heard that the replacement pads/rotors will still have that problem. Either the pads are too hard or the rotors are too soft.
Has anyone tried Cryo treated rear rotors with Hawk HPS pads?
Yes, I had the low groaning for a while...then it sounded like I was dragging the e-brake....that is when I took it in. That pic that I posted is the inside of the rotor, it was the side that was tore up. The outside of the rotor looked normal...but it had thermal stress marks all over it.
Hope there is nothing wrong, hate the thought of yet another trip to the stealer, er, dealer. Twice now with hanging revs, slow idle return issues (as yet unresolved) and they never keep the car overnight so I'm on my own for mooching a lift to work and back. 3 times in 6 months just doesn't seem right somehow
9k on my car. found this issue right before i was due to drive 550 miles home from vacation. dealer said they would order new pads and resurface my rotors. to which i stated i wanted new rotors because that decreases the life of my rotors. we'll see what happens.
they said the pads are at fault. faults in them where somehow impurities got in.
uhh ohh.... the dealership is gonna hate me.... just got my entire sunroof assembly replaced under warranty today...my rear brakes sound like my ebrake is on too... like a low grinding sound when i'm almost stopped and the inside of the rotors look just like that ( big deep grooves) and i have an 08 with about 20k on it but the fronts are fine. now shouldn't the fronts go out first considering thats where most the braking power is? will they replace these under warranty do you guys think? just curious cause i was gonna replace them myself but if i can make them eat another couple hundred then why not lol
brake pads should wear rotor evenly, no giant grooves like this. i was told there was a service bulletin about the issue by dealership. gm is aware of the problem and should fix it under warranty for you
I placed the order for Hawk HPS rear pads from Summit Racing, $79 shipped but it is backordered for several weeks. If GM goes bankrupt and can't make my Cobalt, I can always cancel the order for the pads.
does anyone got a name/number to their dealer that dealt with their car, mine is giving me hell since there is no recall and i have 24k on the car, damn rotors are grinding for god knows how long, my g/f drives the car up and down the interstate daily 100+ miles a day so hardly any of the miles been city. I need to get some more info on this to provide them with enough reason to warranty this.
thanks
thanks
thanks
thanks
same thing happend to my friends rears that had only 2,500 miles. this **** is ridiculous. almost makes me not want to save up and get one if i have to take it to the stealership every other month.
well talked to the d- specialist and tomorrow he is supposedly is calling me back with a authorization number to have the rear brake componets replaced. probably just end up replacing it myself though, can't stand dealers
thanks for help though
at least you don't have to drive a buick as a rental like I did when I wrecked my car
