Trouble With Serpentine Belt
Old Jul 1, 2018 | 06:04 PM
Kevin Clarillo's Avatar
I recently had trouble with my serpentine belt. The belt shredded off completely. And I bought a new one installed it but again and again the belt does the same thing. I makes a loud screeching sound as if it rubbing on a pulley. I bought a new tensioner pulley recently hoping that the issue but I need help. I don't know the exact steps on replacing the entire belt tensioner. If anyone cam help it would be amazing! I have the 07 SS/SC
Last edited by Kevin Clarillo; Jul 1, 2018 at 06:06 PM. Reason: Left something out
Old Jul 1, 2018 | 06:15 PM
Henry3959's Avatar
Remove your belt and make sure every accessory and pulley rotates freely.
Old Jul 1, 2018 | 07:12 PM
Sharkey's Avatar
had the idler pulley seized the bearing and shred a belt on our shops supercharged hhr. ive read about that more than happening several times, so that would be something to check.
Old Jul 2, 2018 | 01:53 PM
I just checked. Yes everything except the camshaft pulley rotate freely.
Old Jul 2, 2018 | 01:54 PM
Whenever I get the chance I'll install the new belt tensioner and I'll see if that fixes anything
Old Jul 2, 2018 | 01:57 PM
Kolt's Avatar
Drive belt replacement.pdf
Belt tensioner.pdf
hope that helps
Old Jul 2, 2018 | 01:59 PM
Originally Posted by Kolt
Came in CLUTCH!
Old Jul 2, 2018 | 02:14 PM
Henry3959's Avatar
Can you take a pic of what you are calling the camshaft pulley?
Old Jul 2, 2018 | 02:29 PM
Kolt's Avatar
Came in CLUTCH!
What?
edit: had to google that and np man.... thanks for making me feel old
Old Jul 4, 2018 | 10:12 AM
jdbaugh1's Avatar
I had my idler pulley, the pulley to the counterclockwise side of the tensioner pulley, bearing go out and completely destroy itself though I caught it before it damaged my belt. This part is not easy to see from the top. Did you check it?
Nfangelo
Jun 4, 2011 08:36 PM
goldchain69
Jun 28, 2010 09:01 AM
Joewit
Nov 7, 2006 08:08 AM
03gobluecobra
Jul 22, 2006 05:15 AM
