trunk won't open
Old May 19, 2008 | 08:44 AM
gtzjustin's Avatar
Angry trunk won't open
so my 05 ls trunk won't open by remote or the button in the dash tray. only can get in with the key. if i push the button on the remote the lights flash but no "pop". I was gonna check the fuses but can't seem to tell which it is. i checked the panel cover and the owners manual both. any ideas before i tear into this?
Old May 19, 2008 | 08:45 AM
Jackalope's Avatar
Yeah its an 05, go to the dealer! WARRENTY!
Old May 19, 2008 | 08:47 AM
gtzjustin's Avatar
out of warranty, 42,000 miles
Old May 19, 2008 | 08:49 AM
SilvrLT's Avatar
There is no warrenty if it's an 05, Check th fues under the hood, it could also be a bad acuator
Drakonen2000's Avatar
you probably have a bad trunk pop'er. Because if the lights are flashing then you know its recieving the signal, and the relay is activating...sooo...since i know the trunk pop'er is not on ist own fuse, i would have to say that either it is bad, or the wiring to it is bad!
Old May 19, 2008 | 08:58 AM
Jackalope's Avatar
3 year 36,000 mile bumperto bumper warrety. A late model 2005, it was worth a shot. *shrug* But mileage killed him.
Trunk solinoid as mentioned above if its not a fuse.
Old May 19, 2008 | 09:04 AM
mkulrey13's Avatar
Its the fuse, I had the same problem. Jsut replace it and your good to go
wrong
Old May 19, 2008 | 09:07 AM
gtzjustin's Avatar
would've been good till july if not for mileage
Old May 19, 2008 | 09:17 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Fuse.tv for sure
Old May 19, 2008 | 09:20 AM
wrong
really?? i just wouldnt have guessed that its on its own fuse....eh, i guess its better for the OP that way ne how!
Old May 19, 2008 | 10:20 AM
seller232004's Avatar
fuse, happened to me a couple times already, your ac plug/cig lighter should not work either, their all 1 fuse in the box under th hood.
Old May 19, 2008 | 10:26 AM
umrdyldo's Avatar
fuse, happened to me too.
Wonder why this is so common
Old May 19, 2008 | 10:31 AM
Coblasts's Avatar
Fuse is under the hood Trunk/Outllet 20 amp.
also check the trunk release relay should be right there as well
Old May 19, 2008 | 08:12 PM
gtzjustin's Avatar
thanks for the info everyone, gonna check it out soon as the rain stops
Old Jun 16, 2008 | 07:21 PM
gtzjustin's Avatar
Just to up date everyone.... it wasn't the fuse or the relay. So I pulled the carpeted panel off the trunk and of course you can't see the solenoid or the wiring. But it turns out the plug from the wiring was about half way out of the socket on the solenoid.
Thanks again everyone!
Oct 13, 2015 09:32 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
soaxin
Sep 26, 2015 08:41 PM
