TSB: Ignition Key Difficult to Remove
Old Aug 11, 2009 | 07:51 PM
rukkee's Avatar
Service Information
2009 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | View All Bulletins | Document ID: 2325129
#09-02-35-005: Ignition Key Difficult to Remove, Ignition Key Binds or Sticks in Cylinder (Replace Ignition Cylinder) - (Aug 10, 2009)
Subject: Ignition Key Difficult to Remove, Ignition Key Binds or Sticks in Cylinder (Replace Ignition Cylinder)
Models: 2008-2009 Cadillac CTS (Built Prior to VIN Breakpoint 90163371)
2005-2009 Chevrolet Cobalt (Built Prior to April 14, 2009)
2006-2009 Chevrolet HHR (Built Prior to April 14, 2009)
2007-2009 Chevrolet Equinox (Built Prior to July 2008)
2005-2006 Pontiac Pursuit (Canada Only)
2006-2009 Pontiac Solstice (Built Prior to April 14, 2009)
2007-2009 Pontiac G5 (Built Prior to April 14, 2009), Torrent (Built Prior to July 2008)
Attention: This bulletin only applies to vehicle equipped with automatic transmission.
Condition
Some customers may comment that the ignition key is difficult to remove or that the key sticks or binds in the ignition cylinder.
Correction
A new ignition lock cylinder has been released to correct this concern. Replace the ignition lock cylinder. Refer to Ignition Lock Cylinder Replacement in SI.
Parts Information
Part Number
Description
20869121
Cylinder, Ignition Lock (Uncoded)
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
E7200
Use Published Labor Operation Time
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2009 General Motors Corporation. All rights reserved.
Shanman
ZZ Performance
43
Aug 26, 2016 08:43 PM
satisfied
Oct 19, 2015 12:35 AM
How to Guide
57
Oct 15, 2015 11:56 AM
Cptnslo
Sep 24, 2015 09:32 AM
katahdin_lubricants
Sep 20, 2015 07:24 PM
