Turbo Flutter- 5PSI
Old May 15, 2012 | 07:59 PM
pummy023's Avatar
Turbo Flutter- 5PSI
This is the second time this is happening to me. I have bad turbo flutter whenever I shift and my boost only goes up to 5 psi. The first time I took it in to the dealer, they said I had a small hole in the bottom of my charge piping. They replaced it and it was running fine for about 6 or 7 months. Now the same problem is back. Anyone else have other suggestions on what could possibly be causing this?
Old May 15, 2012 | 08:08 PM
MastaShaKe_88's Avatar
check yourself to see if theres a hole in your piping or intercooler, are you in limp mode or showin a CEL or anything?
Old May 15, 2012 | 08:11 PM
pummy023's Avatar
im pretty new to this. It hasnt thrown any codes, and what does limp mode mean?
Old May 15, 2012 | 09:31 PM
bluebalt07's Avatar
It basically means that the computer has detected a problem and reduces the engines power so that it can't damage itself.
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
