turbo kills ac?
turbo kills ac?
Idk wtf is goin on but if I have the ac on and roll up to a light the rpms dip to the pt of shutting the car off. Its sooo annoying. I'm chalking it up to being turboed cuz it didn't do that before. anybody have any roundabout ideas?
bump helpppppp!!! its hot in tx and this is soo weird.
is it JUST when you have the ac on coming down from rpms from driving to idle? or if you were sitting and good and then clicked it on it happens?
does the car try to recover before dying?
ok when i coast up to a light i usually shift into N at about 1k... if i have the ac on it dips hard to like 500 and tries to recover then it dips again. if i tap the gas it centers back to 900... if i dont have the ac on im fine. for a while i was ok with turnin it off before i stopped then turning it back on when im completely stopped but a couple times it still dropped idle. basically i have too much load on my car?
my volt meter was still showing around 14 volts so i figured id be ok.
this happens to me (no boost) but lots of mods on my 2.2
if i compression brake and then as i get close to an idle i pull the clutch out a lil to keep the engine moving via the tranny moving to even it out...if i dont sometimes it dies....
im not sure if it has to do with the idle specifically, with the afr as you get close to idle...im not sure....
but im guessing it can be fixed witha tune
mine also got better over a little bit of time, it only does it once in a blue moon now...
