turbo LSJ stuttering. HELP!
Old Mar 26, 2013 | 02:46 PM
Killa SS's Avatar
I just swapped out the plugs too 2 step colder race plugs. this is when the issue began. i was getting on the highway and got on it. did some odd pops then stutter/misfires.
the codes i got was p0230 and p0503. every time i get to around 9lbs of boost it starts misfiring an has no power. i swapped back to my old plugs. issue still exists. compression check shows 180 for all 4cyl and no loss of compression. i swapped coil packs around and issue still exists car drives normal. until i get on it. or try to atleast. ive cleand the maf with maf cleaner. I have a WOT box and i reprogrammed it and checked wiring and all is good. with it.
during the misfires my interceptor showed 72 misfires. 0 knock. maf air flow lbs/m were between 20-35lbs/m and afr was showing 14.8
I run full e85 car's built and tuned by zzp has ran fine for the past couple weeks since getting out of storage. I have a return style fuel system with a 255 walbro 80# injectors.
can any one give me an idea what to check to fix this issue. any ideas. i do not have HPT only an interceptor. i still have the factory battery as well. i have searched and i dont know if those issues were as severe as mine is. im not sure if swapping the battery will fix this problem.
Old Mar 26, 2013 | 02:48 PM
turbosmart4's Avatar
Why would the battery be bad? Have u checked the voltage w the interceptor?
Old Mar 26, 2013 | 03:08 PM
Killa SS's Avatar
i checked voltage thru turbo timer. 14.2
battery sat outside all winter. brought it in once it started warming up to charge it. i havent had any issues electrical wise till this started yesterday.
Old Mar 26, 2013 | 03:11 PM
Bad-A-SS's Avatar
When in storage did you leave any E85 in the tank?
Old Mar 26, 2013 | 03:12 PM
Area47's Avatar
Rent me! per hour
lower the gap on the plugs.
Killa SS's Avatar
yes. its gone thru 3 tanks of gas since then. only a 1/4 tank was in it over winter. and i added iso-heet to it when i filled up. ran that tank out nearly completely and have filled up twice since then
Old Mar 26, 2013 | 03:13 PM
JapEatr's Avatar
South Central *********
sounds like spark blowout, tighten that gap. also E85 needs less of a colder plug than gas, so -1 step is coldest i would go
Killa SS's Avatar
gaps are at .028 on one step colder plugs and its still having problems the 2 step colder plugs were also at .028
Old Mar 26, 2013 | 03:14 PM
Bad-A-SS's Avatar
Listen to Area regap those plugs
Old Mar 26, 2013 | 03:22 PM
Killa SS's Avatar
and the stutter/misfire doesnt stop until i take my foot out of it. and i have to get back in to it easy. what about the springs in the coil pack boots? they look discolored
Old Mar 26, 2013 | 03:30 PM
Area47's Avatar
Rent me! per hour
bkr7e plugs
gapped at .025 as a base.
Old Mar 26, 2013 | 03:31 PM
Killa SS's Avatar
bkr7e plugs
alright. ill get some. but why wasnt it doing this before? the one step colder plugs i had in prior were at .032 all last fall and i had no problems what so ever
Old Mar 26, 2013 | 04:36 PM
Tjolley's Avatar
My car did the same thing.
Turned out to be all the injectors went to ****.
Old Mar 26, 2013 | 05:24 PM
Killa SS's Avatar
That would suxk. The afr is being pretty funk. I wonder if my 80s have gone static? Idle is now gettin shitty and bouncy
Old Mar 26, 2013 | 05:52 PM
pecorillif's Avatar
Cuz your car is slow. Just get the 2000cc injectors and tune better. Gap plugs better. And deffently driver mod.
Old Mar 26, 2013 | 05:59 PM
MrSlickSter06SS's Avatar
Hmm interesting lmao mine is doing the same thing, and I aint got a clue! a/f drops to 10 flat if i try to tromp on the gas, it just face palms and drives like ****.. tryin to figure some **** out myself good luck bud.
Old Mar 26, 2013 | 06:07 PM
Killa SS's Avatar
mine isnt going rich but stayin in the 14s. thanks man. good luck to you.
frank. suck a bag of dicks
Posted from Cobaltss.net App for Android
Old Mar 26, 2013 | 06:25 PM
Killa SS's Avatar
im taking the car to zzp in the morning. ill update this when we figure something out
Old Mar 26, 2013 | 07:16 PM
sweet. def let me know! much appreciated.
Old Mar 27, 2013 | 12:51 PM
Killa SS's Avatar
I had two bad coil packs :/ lamee
Old Sep 8, 2014 | 03:47 PM
boostbalt's Avatar
My car does the same thing, coil packs eh, where did you replace them?
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
maliki778
Oct 1, 2015 07:39 PM
