Turbo Timer pointless?
Old Aug 5, 2008 | 11:15 PM
ChevyRedline2006's Avatar
Okay so I drive an SS/SC and i put a timer on it....it does what it's supposed to however the auto lock feature in the car and the fact that the stereo system stays on until the driver side door is opened after the engine shuts off completely defeats the purpose of putting a timer in ur car. As soon as i shut off the engine my doors unlock, the timer goes and the engine keeps running. so i get out and because my engine is still running my stereo doesn't shut off, then i shut and lock my doors again. but when the 30 seconds or however long it's set to is up the engine shuts off and the doors unlock again, then i have to open my door to turn my stereo off. So in the end I stand around waiting for the timer to finish what its doing so i can do my normal stuff and lock up the car. My question for you guys is, is there a way to disable the autolock system and the stereo staying on til the door opens? because if not then there is really no point in installing a turbo timer on the cobalt. Lemme know ppl please
Old Aug 5, 2008 | 11:16 PM
sick06cobalt's Avatar
you drive a car with a supercharger.... not a turbo....
Old Aug 5, 2008 | 11:17 PM
cblt12's Avatar
sorry about your luck
hatrickstu's Avatar
why in the world would you do that. do you even know what a turbo timer is "supposed" to do?
Old Aug 5, 2008 | 11:19 PM
Super_SS's Avatar
TURBO TIMER>>.
T>U>R>B>O <<<<---- Any clues?
give it to ^^this guy.... he has a SRT (neon)
IR0NS1N's Avatar
Originally Posted by ChevyRedline2006
Okay so I drive an SS/SC.... there is really no point in installing a turbo timer on the cobalt. Lemme know ppl please
BAHAHAH thanks for the laugh
Old Aug 5, 2008 | 11:23 PM
theneelster's Avatar
A turbo timer is not really necessary even in a turbocharged car. Sort of like a reverse remote starter meant to cool down rather than heat up. I have no idea about the passlock system being removeable or disable-able but again it would probably just be cheaper to disconnect that turbo timer.
But I must say...more electronics ftw. Especially at night!
Super_SS's Avatar
beh, that was my first mod too on the neon, but i have a greddy one. its blue ;-D
Old Aug 5, 2008 | 11:24 PM
lol thats funny... isnt your car orange?
Old Aug 5, 2008 | 11:26 PM
Super_SS's Avatar
BAN?!?!?!?
Old Aug 5, 2008 | 11:28 PM
HackAbuse's Avatar
nominated for best thread of 2008
Old Aug 5, 2008 | 11:29 PM
lol hack...
Originally Posted by Super_SS
BAN?!?!?!?
give me a break ive never seen your car....
Last edited by sick06cobalt; Aug 5, 2008 at 11:29 PM. Reason: Automerged Doublepost
Old Aug 5, 2008 | 11:30 PM
IR0NS1N's Avatar
I second that nomination.
Ive never seen his car either, Im going to guess its sliver though just by his sig and avatar
Old Aug 5, 2008 | 11:31 PM
yeah but there is orange... so well see... anyway... it doesnt match... that was my point.... lol
Old Aug 5, 2008 | 11:32 PM
originaladrian's Avatar
oohhh man... this is bad...
Old Aug 5, 2008 | 11:39 PM
wow it was a simple question ppl relax. it doesn't have to have a turbo to put the timer on it, or does it? is it an absolute requirement? no it's not its supposed to help cool down the car before the engine shuts off, not turbo specific, u could put one on an NA if u wanted. Maybe I'm mistaken but I just put it on because I heard it helped cool the car down, sorry I don't know everything there is to know bout cars, jeez...
Old Aug 5, 2008 | 11:42 PM
its chill but its called a turbo timer for a reason.. you cant put them on an NA car.. and really shouldnt do it on an s/c car because the s/c spins using pullies and belts... the reason you use a turbo timer on a turbocharged car is becuase a turbo uses exhaust gases... so to cool down the turbo you cool down the engine which cools down the exhuast which cools down the turbo...
Old Aug 5, 2008 | 11:43 PM
EmperorJJ1's Avatar
the whole point of a turbo timer is to cool down the turbo from the massive heat its subjected to while running. basically preventing it from cracking. There is no heat issue with the charger
Old Aug 5, 2008 | 11:44 PM
HackAbuse's Avatar
Actually you're doing the opposite, if you leave the car sitting idling, it'll run hotter than if you were driving it down the street.
Turbo timers are used to cool turbos by circulating coolant (oil or water) thru them after you are done putting load on the engine
On any other car, you're just adding heat to the engine and wasting gas.
Old Aug 5, 2008 | 11:54 PM
http://www.statracing.com/buy/greddy-turbo-timer.asp
Here you go...a turbo timer can be installed on ANY car...just there really isn't a point on most cars.
Old Aug 6, 2008 | 12:02 AM
I answer you with this:
the GReddy Turbo Timer is our favorite turbo timer and one of the classics that have been used in both import cars and domestic. The basic function of the GReddy Turbo Timer is once you turn your car off, the GReddy Turbo Timer takes over, and doesn't let your car turn off until the countdown is reached. During this pre-set time that you select, say 30 seconds, the car remains idle to allow the turbo system and all of the turbo components to cool. The GReddy Turbo Timer will turn the car off once the countdown has been reached. This ensures your turbo system, turbo, and everything related, last longer and perform better, and does not get oil choked in any of the lines. We highly recommend the GReddy Turbo Timer for all turbocharged, supercharged, and any vehicle that you want to give a cool down period. You can set the GReddy Turbo Timer to let your car idle up to 3 minutes while you are not in the car.
Shutting down a turbo engine "hot" can cause "Heat Soak", where the temperature of the oil inside the turbo gets hot enough to form a varnish or a hard coke that can harm turbo bearings and seals. In addition to using a good quality oil, our Turbo Timer will let your engine idle down to safe temperatures securely without the inconvenience of sitting in the vehicle for minutes. The *NEW* GReddy turbo timer features voltage display with warning, full auto countdown mode, lap time, 0-200m, 0-400m, 200-400m, 0-100km/h, 0-200km/h, and speedometer display with peak/hold.
Did you ever think that they would say this just to sell some...? look up greddy and see what they say...
Old Aug 6, 2008 | 12:05 AM
reaper89's Avatar
from reading that it doesnt do anything unless u beat the **** out of ur car to reach non safe temps....
Old Aug 6, 2008 | 12:06 AM
HackAbuse's Avatar
Idling a car when it's not moving doesn't "cool it down"
It heats it up, lol
Old Aug 6, 2008 | 12:07 AM
R&C_rallySS's Avatar
Most of you guys are about 90% correct when it comes to a turbo timer. Trust me when I say I know what and why you need a turbo timer. Some turbo cars do not need a turbo timer because of the type of turbo and or the system that it runs off of. With my Syclone I need a turbo timer, or I need to keep the truck running after hard turbo use. If I'm just daily driving it and not boosting often I can just shut it off like normal.
A turbo timer will keep oil or water running through the turbo lines so the turbo does not go bad over time. If you don't have one, and you don't let it run after boosting often. The very hot oil/water will just sit inside the lines and your turbo will not cool down. This mainly caused bearings to go bad, but also can lead to cracking or worse.
Moral of the story: If you have a turbo on your car and you want to mod for more HP, you need a turbo timer. If you drive a N/A or supercharged vehicle, you do not need a turbo timer.
