two problems please help
first, i changed the brake lights to leds and now they flash fast when i turn on the turn signals. has this happened to anyone else.
second. does anyones seat belt lock when not buckled to keep you from inserting the male end so it is buckled. if so please let me know. if anyone can help me i would apprieciate it.
You need resistors. LED's draw a lot less current, so your car thinks the incadescent bulbs are blown out and is flashing them quick to let you know. http://cgi.ebay.ca/Load-Resistors-LE...item588458a6a2
As for the seatbelt thing... I have no idea. Mine's alright. Sometimes it get a lil stuck have to just wiggle and tug on it a bit.
X2 on the resistor.
And the seat belt problem look insde it maybe a coin fell inside.Otherwise they are not serviceable and needs to be replaced.
Im sure you can pick one up at the wreckers for a few bucks unless you have warranty.
