Upstream O2 in the rear
Old Dec 12, 2013 | 06:26 PM
iToastie's Avatar
Is it possible to use an upstream (front) o2 sensor in the downstream (rear) spot? Or do they use opposite connections?
Old Dec 12, 2013 | 06:31 PM
blueLNFftw's Avatar
I wish you would have asked this question 45 minutes ago, I just had them both out.
I want to say the connectors are the same because I have heard of people plugging them in wrong, however, I do not think that can interchange.
Did you check the part numbers on them?
Old Dec 12, 2013 | 06:34 PM
Corey V's Avatar
They should be the same if I am not mistaken
Old Dec 12, 2013 | 06:46 PM
iToastie's Avatar
From researching, I know the front o2 sensor has some extra magical **** in it that the rear doesnt use, but if I plugged it in the rear, wouldn't it only use what it needs?
Old Dec 12, 2013 | 06:56 PM
Corey V's Avatar
On most cars they are interchangeable I'll check the P/N and see.
Old Dec 12, 2013 | 07:05 PM
Corey V's Avatar
They are the same
Old Dec 12, 2013 | 07:12 PM
chevygirl2006's Avatar
They have a different plug
Old Dec 12, 2013 | 07:13 PM
Originally Posted by Corey V
They are the same
Assuming these are both true, it wouldnt be hard to make it work.
Last edited by Slowbalt2000; Dec 12, 2013 at 07:13 PM. Reason: Automerged Doublepost
Old Dec 12, 2013 | 07:26 PM
iToastie's Avatar
Lmao
Well I was told the plugs were different from other sources.
I'm going to get a plug until I get the proper one.
Old Dec 12, 2013 | 08:21 PM
Cherry GT's Avatar
She is correct.
Front sensor plug is female connector...
Rear sensor plug is a male connector...
Old Dec 13, 2013 | 09:24 AM
mrbelvedere's Avatar
you need to post questions like this in the general section or in the problems and service section not the performance section
Old Dec 13, 2013 | 01:27 PM
Tomtwtwtw's Avatar
If we're talking LNF your upstream is your wideband and your downstream is just a generic o2 sensor. The upstream is a different part and costs a good deal more.
Old Dec 13, 2013 | 06:48 PM
06blackbalt's Avatar
They are 2 different sensors. The front sensor (B1S1) is the Air fuel sensor
The rear (B1S2) is just a normal heated oxygen sensor for post cat readings. They can not be interchanged
Old Dec 13, 2013 | 07:07 PM
tomj77's Avatar
im pretty sure the front has 6 prong plug and the back has 4 so no
I could be wrong
Old Dec 13, 2013 | 10:27 PM
He has an LSJ.
Old Dec 13, 2013 | 10:58 PM
iToastie's Avatar
You need to stop posting useless posts.
And I got it figured out...
The rear has a male end and the front is a female end.
Old Dec 15, 2013 | 07:16 PM
Tomtwtwtw's Avatar
He has an LSJ.
Ah. Well they're still different, just no wideband. OP should have specified though...there's a picture of a Cobalt with SS/TC wheels in his sig.
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Delta coupe
Sep 30, 2015 08:11 AM
