Vacuum leak??? P0171 code
Old Oct 21, 2008 | 10:33 PM
ItalianJoe1's Avatar
Ok, I need some input here:
I just wrapped up a rebuild for a local guy who had a couple cracked pistons. All stock parts back in the car, back to 100% stock, stock tune, everything. The car was denied warranty at a dealership, so I had to re-build the motor from a box of parts, I didn't do the teardown. Motor started right up beautifully, and runs nice and normal. Only issue i'm having is what I believe to be a vac leak. Car doesn't want to idle smooth when cold, and once its warm, its manintaing a smooth idle but has to go into the 30% range on STFT to get there. Throws a constant P0171 fuel trim lean code. O2 readings are basically lean all the time, even when driving, it swings back up but drops right back and holds lean.
If you blip the throttle at idle, the car takes a second to smooth back out, it has to trim itself back to 30% or more to be smooth, but once it gets there it seems fine.
Just looking for more ideas on this, I've gone over most of the obvious stuff, but I could have missed something or overlooked an item. What have you guys got for me? Thanks.
Old Oct 21, 2008 | 10:35 PM
impulseballer's Avatar
sounds like most cobalts out there with a CAI lol
Old Oct 21, 2008 | 10:36 PM
Raven SS's Avatar
o2 sensor bad?
Old Oct 21, 2008 | 10:44 PM
Umm, its stock airbox, and it wont run smoothly or idle down right... I haven't seen a CAI do that.
Originally Posted by Raven SS
o2 sensor bad?
Wouldn't it throw a code?
From what I understand, the O2 was replaced before I got involved with the car, but it was also a badly blown engine at the time. I could pull it and check I guess, that was one of the ideas I was thinking about tonight.
Last edited by ItalianJoe1; Oct 21, 2008 at 10:44 PM. Reason: Automerged Doublepost
Old Oct 21, 2008 | 10:45 PM
Altiery54's Avatar
interesting is it also throwing a p0300? mine is throwing a p0172 which is rich instead of ur lean in ur case.
BLAZIN07SS's Avatar
I'm too JDM for you
hmmm. MAP sensor maybe? i was ******* around with my car today and the map sensor was unplugged a little. car idled like ****
Old Oct 21, 2008 | 10:46 PM
Altiery54's Avatar
does the car run perfect at WOT?
i was cracking a joke and most cobalts with CAI throw P0171 code and idle funny at times.
Old Oct 21, 2008 | 10:47 PM
Altiery54's Avatar
thats was chris's problem
Raven SS's Avatar
local dudes car had the flex pipe blow out on a zzp downpipe and it trashed his o2 sensor and it did this...with no codes other than the lean bank 1
Old Oct 21, 2008 | 11:14 PM
Nope, only the 0171
No, car idles fine once it trims itself back to the right level.
Hard to say, the car surges under throttle, but I put new rings in, so I haven't really pushed the car hard at all, break-in and all that good stuff...
Sorry, not in a joking mood about this car. Its been taking a ton of my time, I'm not getting paid enough, and I had to clean up after some GM tech dumbfuck who didn't even know how to remove the front cover...
Ehh, he had a bad sensor, which would spike once in a while, causing the "fuel cut" as he called it.
Same kind of wonky idle ****, fuel trims way out?
This car has full stock exhaust now, but it didn't the last time I saw it before the motor got taken apart. So anything is possible. I guess i'll have to get under there and take a look. Doesn't sound like an exhaust leak at all though, car is perfectly quiet and stock sounding.
Last edited by ItalianJoe1; Oct 21, 2008 at 11:14 PM. Reason: Automerged Doublepost
Old Oct 21, 2008 | 11:16 PM
Raven SS's Avatar
im sure u know this joe but did u try spraying soapy water over the engine? and yea hes car was bad on the trims...o2 was shot
Old Oct 21, 2008 | 11:17 PM
I was doing that somewhat tonight, but it was pretty dark, so I gave up. I think I hear a vac leak sometimes, but then I don't... I pushed each injector down, felt all around everything, all the **** I could think of...
Also, car is only holding about 17 in/hg at idle, not 20ish like most stock cars.
Old Oct 21, 2008 | 11:19 PM
Raven SS's Avatar
the car will do that until the rings set...mine held 8in/hg
Old Oct 21, 2008 | 11:29 PM
Stock rings?
My car had massive vacuum until it broke in, over 20in/hg at idle, over 25in/hg coastdown in gear.. now its not so much at idle, but that may be due to some... other modifications
Old Oct 21, 2008 | 11:31 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Stock rings?
**cough** cams **cough**
Old Oct 21, 2008 | 11:32 PM
Raven SS's Avatar
no it was overbore diamond pistons/rings mine was 8 then when it finally broke it it was 12...with a tvs...i could build 5psi in neutral off the tvs
Old Oct 21, 2008 | 11:33 PM
Who, you??
Oh, BTW...
SHUT THE **** UP!!
Weird, mine was the diamond stuff, stock sleeves and ****, but huge vac, more than stock. Unless it was because of the fresh valve job and stuff, but its wierd that mine was higher and your build was lower.
Last edited by ItalianJoe1; Oct 21, 2008 at 11:33 PM. Reason: Automerged Doublepost
Old Oct 21, 2008 | 11:36 PM
Raven SS's Avatar
i had jbp triflows too with a massive port job and oversized valves
Old Oct 22, 2008 | 12:28 AM
bump for more ideas...
Old Oct 22, 2008 | 04:06 AM
fzn14's Avatar
Whoa....This whole topic is exactly where i needed to start...Car has been stock and ran good(07 SS/SC) and when i took off the air box i hit the 171 all the time. I added OTT stage one and Vibrant down pipe and now getting 171,1101,AND 300. Has anyone come up with a fixing for this...O and i am having boost issues as well....
1st pull 15-18 pounds like i should(have a 2.8 pulley)
2nd pull14-15 pounds
3rd pull-hits 14-15 and pulls it down to twelve and holds it
Any help?
Old Oct 22, 2008 | 04:26 AM
Raven SS's Avatar
buying canned tunes is a fail...no matter what vendor u get it from
Old Oct 22, 2008 | 04:42 AM
Witt's Avatar
Start pinching vacuum lines with your fingers and see if anything changes.
If you have access to HPTuners, open VCM Scanner and connect to the PCM. Enter the area with the icon ON/OFF (the place where you can adjust idle manually) and check commanded idle to actual idle. Also note idle spark at the same time. If either actual idle is higher than commanded or they are the same and you are pulling consistently negative timing at idle, its probably a vacuum leak.
If you are running any open air crankcase breathers, get rid of them. Keep the PCV system closed until the problem is diagnosed.
Old Oct 22, 2008 | 04:52 AM
Darkmanx's Avatar
You tryed the 02 yet joe?>
Old Oct 22, 2008 | 08:15 AM
QuikSilverSS's Avatar
mine does to! the only code I throw is P0172 and its usually after I am sitting in or just after a traffic light.
Sorry i know that doesnt help your issue Joe
