Very urgent question: Fogs
Hey guys,
So, I just got my HID's in today and set them up. Everything works great in my projector H1's, but the fogs aren't working right. It seems like I blew a fuse for the passenger side foglight, but the issue is that I can only find one fuse for the fogs (drivers side). Where the hell is the other one?? The drivers side is working great, but the passenger side won't come on at all. Even flicker. That's why I'm suspecting a fuse. The ballast, light, and all wiring is good because I cross checked from the drivers side. Any ideas or help on the other sides fog bulb??
Thanks!!!!!
Thanks!!!!!
just looked at the diagram it uses the same fuse but different grounds for each light.
G102 location left front engine compartment on crossbar at washer reservoir fill cap
same ground used for the right hi/lo beams.
did you splice into a ground wire to get the right HID'S to work?
here is a diagram http://s262.photobucket.com/albums/i...t=foglight.gif
I actually figured it out later that night.. lol There was nothing wrong with the components.. I just switched the positive and negative wires up in the adaptor piece to plug into the harness. It wasn't marked. It didn't fry anything, but rather, just not turn anything on. But as soon as I switched them, it's been working perfect.
Thanks!
Thanks!
