Vibration
Old Apr 17, 2007 | 10:56 AM
blk_cobalt's Avatar
Vibration
hey i find when i'm turning right with my car i feel a vibration on the pedals and also the passanger feels the vibrations. This does not happen when i'm turning left.
if anyone has any clue of what this is or if it's something minor i would appreciate the advice
thanks
Old Apr 17, 2007 | 11:22 AM
eazyasone23's Avatar
see if ur car needs it wheels to be balanced or maybe you have a bent rim and dont know it. i know i had a similar problem but then i switched out to my spring/summer rims and it went away.
Old Apr 17, 2007 | 10:10 PM
mr.oakes's Avatar
i had that same problem with my cobalt it took them about four hours to figure it out but it was bolts holding the transmission.they said it it just needed to be tightened easy fix
Old Apr 17, 2007 | 10:17 PM
biniecki's Avatar
also if you have aftermarket rims try some hubcentric rings
Old Apr 19, 2007 | 12:55 PM
kovich14's Avatar
along the lines of what mr.oaks said, i have a similar porblem with mine, and the dealership noticed that the transmission mounting bracket was rubbing against a steering component. they reset the mounting bracket and it went away. fyi
Old Apr 19, 2007 | 01:51 PM
fr33k's Avatar
There's a TSB for that problem. It might not be the exact thing, but it's worth a try.
The 07's, like kovich14's, has a different TSB for the turning noise.
06 TSB is below. farther down is the one for the 07s.
Document ID# 1861084
2006 Chevrolet Cobalt
Subject:Steering Column Shudder, Noise, Vibration While Making Right Hand Turns at 5-15 MPH (8-24 KM/H) (Pull Fuse) #06-02-35-008B - (09/08/2006)
Models: 2005-2007 Chevrolet Cobalt
2005-2006 Pontiac Pursuit (Canada Only)
2007 Pontiac G5
This bulletin is being revised to provide additional diagnostic information. Please discard Corporate Bulletin Number 06-02-35-008A (Section 02 -- Steering).
Condition
Some customers may comment on a shudder, noise or vibration that is felt through the steering column while making right hand turns at 5-15 mph (8-24 km/h). This condition can be duplicated by the technician. Removal of the 60 amp fuse that powers the EPS may eliminate the condition.
Correction
DO NOT REPLACE THE STEERING COLUMN.
Replacement of the steering column, P/N 10394224, is NOT recommended. Steering column replacement has been proven to be ineffective in several Technical Assistance cases.
Pull the 60 amp steering fuse (1) in the underhood fuse block. If this eliminates the shudder/vibration concern, contact Technical Assistance for further information in order to repair the vehicle. If this does not eliminate the shudder/vibration, continue to diagnose the vehicle according to the diagnostics in SI.
07 TSB for turning noise:
Document ID# 1883830
Subject: Vibration That Is Felt Through The Steering Column While Making Right Hand Turns - keywords acceleration accelerate condition driver full gear ground growl int intermittent MN5 moan noise only out #PIC4305 - (01/03/2007)
Models: 2007 Chevrolet Cobalt
2007 Pontiac G5
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment on a shudder, noise or vibration that is felt through the steering column while making right hand turns at half to full throttle. This condition could be caused by the rear transmission mount grounding out on the Rack & Pinion top hat.
Recommendation/Instructions:
If you suspect that your vehicle has this concern, then put the vehicle in the air and inspect the drivers side of the transmission mount. If you notice or see a witness mark on the transmission mount, then you will have the above concern. It's recommended that if you have this issue to please make the following repairs.
Loosen the front and rear trans mount thru bolts and shift/pry the transmission upward.
You will get enough movement to create enough distance and eliminate this concern.
After you have enough clearance, then tighten the thru bolts to 100 Nˇm (74 lb ft).
Important: Check for presence of excessive shake at idle after shifting mount, may have to re-adjust mounts.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Old Apr 20, 2007 | 10:07 PM
blk_cobalt's Avatar
mine is an o6 and it does vibrate at 8-24km thanks alot
but i don't understand what to do after i pull out the 60 amp steering fuse?
and also can i do this myself or should i bring to the dealership
Old Apr 20, 2007 | 11:02 PM
hmm interesting
Old Apr 27, 2007 | 03:22 PM
blk_cobalt's Avatar
i went to the dealership and i gave the TSB and they said they changed the steering column and guess what the vibration came back, some dealerships are so useless,
should i bring it back?
supajut
Dec 19, 2015 04:06 PM
chefhhr
Oct 26, 2015 10:36 PM
Tupp
Sep 30, 2015 08:18 PM
godsfshrmn
Aug 22, 2006 10:19 AM
