Vibration undoing hose clamps
Old Jan 30, 2012 | 02:27 AM
Micro's Avatar
When I installed my secondary heat exchanger and over-flow tank, I used screw-to-tighten hose clamps instead of the factory style hose clamps. I have modified transmission mounts that transmit vibrations throughout the car that vibrate loose the screw-on clamps. Does anyone know what part number the factory-style hose clamps are? Or, has anyone figured out how to keep the screw-to-tighten hose clamps from vibrating loose?
Old Feb 2, 2012 | 06:50 PM
Coblasts's Avatar
Put some locktite on the threads,the red one I think is the removable type.
Don't use the permanent type or you will need a torch to loosen it after it sets.
Old Feb 3, 2012 | 12:15 PM
Micro's Avatar
Have you tried that? I didn't think there was enough thread touching the base of the clamp to allow proper bonding of the loctite.
Old Feb 3, 2012 | 02:14 PM
rogersj's Avatar
the red stuff is the crazy **** lol if you gonna use any use blue. i would use a tbolt style clamp for hoses the one with a lock nut
Old Feb 4, 2012 | 09:14 PM
Micro's Avatar
Thanks man. That is good advice about the t-bolt style clamps. I was asking some of my "car friends" and they had said to use the t-bolt style clamps too. I'll give it a shot.
Old Feb 5, 2012 | 09:13 AM
rogersj's Avatar
no problem i see it all the time at work lol
Old Feb 5, 2012 | 09:17 AM
05Slowline's Avatar
uhhhh tbolt clamps for heater hose? lol? what clamps are you using that are coming loose.....
Jan 12, 2016 12:01 AM
footballplaya3k
Sep 30, 2015 09:39 PM
Tupp
Sep 30, 2015 08:18 PM
grampss
Sep 27, 2015 08:51 PM
OrangeCoba
Sep 25, 2015 06:06 PM
