Violent Vibration! w/Knocking from front end
Old Feb 18, 2013 | 07:52 PM
StageII07's Avatar
Unhappy Violent Vibration! w/Knocking from front end
Okay i was gonna do a search but im too stressed out right now so heres my problem.
Driving home from work i hit a little dip in the road, No biggy right? Wrong. So im driving hit the bump an all of a sudden my car starts shaking violently under throttle. I hit the clutch an it stops, Let off the clutch an it stops but the moment i get back on the gas it starts shaking. Pull off the side of the highway an start creeping to the next exit doing about 20 MPH, an i hear something slapping around in the front end. I creep an its shakes still but slower shaking like as if i almost had a bent wheel or somthing. I pulled the ebrake an let off the clutch in gear an it wasnt knocking around of vibrating but idk if that rules anything out.. goes into gears fine. Axles look like there fine. Not sure though. Cars lowered cant really get a good look you know?. im thinking axle bind? Or ppl have been telling me the clutch shattered its got a stage 3 spec in it an it has maybee 10k on it? So idk why it would be that but anything is possible, I really dont know what it could be its 747pm right now an its dark and i cant see anything. I did see with the minimal lighting i had that it was not leaking trans fluid. The driver axle has some transfluid on it an on the trans itself near ware the axle is connected but it looks like someone spilled a little trans fluid on it. I dont rememeber if it was like that already. It looked to be fresh fluid. So any opinions on this problem is greatly appreciated. If anyone has had the same symptoms before Please comment! Thank you guys in advanced!
Old Feb 18, 2013 | 08:05 PM
StageII07's Avatar
Oh an the throw out bearing was going bad prior to all to this happening
Old Feb 19, 2013 | 02:28 AM
StageII07's Avatar
nothing guys?
Old Feb 19, 2013 | 06:19 AM
C_A_D88's Avatar
Old Feb 19, 2013 | 07:45 AM
turbosmart4's Avatar
Someone help this guy.
Old Feb 19, 2013 | 08:22 AM
Powell Race Parts's Avatar
sounds like the clutch is done. he says the tob is bad. So the trans has to come out. Not much you can do to help the guy, other than point out the obvious, based on what he has said, and offer condolences.
Old Feb 19, 2013 | 08:24 AM
How do u know when a TOB has gone bad?
And I'm sorry OP my condolences go to u and ur wallet
Old Feb 19, 2013 | 08:36 AM
user 72239's Avatar
you can shatter a clutch hitting a pothole? ive never heard of that before. just wondering
Old Feb 19, 2013 | 09:35 AM
probably not. But thats not the whole story hitting a pot hole may just be the straw that broke the camels back. He said the TOB was on the way out. Assuming the TOB is leaking /failing etc, at some time the soaked clutch lining/slipped clutch etc is going to fail.
This is the internet and some of the questions really are retarded.
" my taps are leaking, whats wrong?"
fml.
maybe his car is falling apart from abuse/loose nuts and bolts/crashing into a 6 ft deep pothole?
we have no way of knowing.
he also has coil overs. Maybe they got damaged.
He has leaking fluid. Maybe the TOB is done
He has a stroker motor. Maybe the flywheel is loose.
I dont know. Do you? I just cant help, can you? He lives in PA, there are some good guys out there that can look at his car and help him?
Old Feb 19, 2013 | 09:36 AM
user 72239's Avatar
fml.
Very true. i just had never heard of a clutch shattering from a pot hole
Old Feb 19, 2013 | 11:28 AM
StageII07's Avatar
Ive never heard it either. An it wasnt even a pot hole. It was just uneven pavement.
Thanx for some help guys.. lol i hope its just somthing stupid, an my clutch really is not destroyed.
Old Jun 20, 2013 | 02:45 AM
SS-C4RP3NT3R-SC's Avatar
Any updates on this? I have the exact same thing happening to me right now too
Old Jun 20, 2013 | 03:04 AM
SlowBalt_06's Avatar
Cv joint
Old Jun 20, 2013 | 03:07 AM
Cobalt_SSTuner's Avatar
When my CAB went, it made it known, but idk if that could be related to this...
Old Jun 20, 2013 | 03:10 AM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Bohb
Sep 27, 2015 09:11 PM
grampss
Sep 27, 2015 08:51 PM
