warning
Guest
Posts: n/a
warning
this is a warning for the rest of the 2.0 owners
this morning on my way to work for some reason i had a urge to turn around so i did when i got home the tranny was locking up . so i jacked the car up and there was a big hole in the differential . now i carried the car to the dealer a couple of months ago for a knocking and they told my that the knocking i was the clutch in need of changing well i had the clutch changed the car was on the road by v day a few days the knocking started again but it kept going away now today there is a big hole in the diff so if any of u guys have a knocking when u accelerat or in between gears have the tranny checked
Guest
Posts: n/a
[QUOTE=rickyw;863910]i get a nock when im stopped it sounds like someones nocking on a door?????? is this how it started out?[/QUOTE
it was not really noticeable at idle it was more noticeable while cruising but if i was u i would get it checked out
i'm thinking of maybe going to a different dealership because this car has been there on three seperate occasions for drivetrain problems.
i get a wierd knock type of niose on my 1-2 shifts and 2-3 shifts some times this usually only happens when i bring it close ot redline not under WOT. it scared me at 1st but then i just started dismissing it as backfire im still on the stock exhaust. now this has got me worried again. it started doing it about 2-3 months ago but its not every shift it will happen like 3-4 times a week
Guest
Posts: n/a
lol that is what i thought it was at first like when i start the balt the dealer even said it was the spring needing oil and as soon as the engine warms up it will stop so i dissmissed it for a awhile but now i wish i didnt
Guest
Posts: n/a
dude i dont think tha is the issue i recieved a phone call this morning about a next balt with the same prob and a girl owned it for a month now bun out or spinnies and the car only had one driver they had to give her a new car and i am sorry to say she did not take a next balt
pictures would be great if possible, and if you have a hole didnt you see diff. fluid on the ground where you parked? i have a wierd intermittant noise that when i take off slowly i hear 1 ping and when im coming to a stop i hear only 1 ping, but its intermittent.
Guest
Posts: n/a
more info on warning
Explanation: https://www.cobaltss.net/forums/problems-service-maintenance-69/knocking-trunk-area-23911/
It is related to the fuel system.
jcalvin1126
Sep 11, 2015 10:24 AM
