Weak hvac blower
Weak hvac blower
Hey guys. My HVAC blower seems pretty weak. If I have it set at the highest setting and only to blow through the top vents I feel like very little air is being moved compared to just about every other car I've been in. Is this normal for Cobalts or something I should consider bringing up to my dealer while I still have plenty of warranty time left?
Does the motor actually change speeds when going from 1 to 2 to 3 to 4? If it only runs at the speed that normally is 1 then your blower motor may have blown the resistor or something. I had something similar happen in my car but where the blower would only run on 4. Dealer fixed it under warranty.
The filter is original but I only got the car in September of 2009. How often do they need to be replaced?
I would say once a year. I never changed mine in my 05 till 5 months ago when I noticed the air was barely coming out. Removed the cabin filter and it had leaves and a bunch of dirt in it. The air started blowing strong again. I also rarely used my air cause my work schedule allowed me to drive when it was cooler out so I kept my windows down.
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
