Weird CEL???
Old Oct 11, 2007 | 12:15 AM
CobaltVenomSS's Avatar
Weird CEL???
for the past 2 tanks of gas ive had i got a CEL at almost exactly half tank and then it goes away around 1/8th tank it has done this on the past 2 tanks of gas....im going to be around half tank tomorrow so well see what happens...
Note: i always use 93 (chevron )
Old Oct 11, 2007 | 12:24 AM
Coblasts's Avatar
Whats Cel are you getting.
Try and get the code to better help you figure out whats causing it.
Old Oct 11, 2007 | 12:26 AM
yea if it comes on again tomorrow i was gonna head to autozone before work
Old Oct 11, 2007 | 12:27 AM
XM15's Avatar
Even if the light isn't on, since it has come on several times the code will probably be there. Get it checked anyways.
Old Oct 11, 2007 | 12:29 AM
anybody know what it might be?
Old Oct 11, 2007 | 03:30 AM
Smitty1017's Avatar
maybe its that one you get from not closing the gas cap tight enough?
Old Oct 11, 2007 | 01:05 PM
yea tighten as much as possible
The light came on today
Last edited by CobaltVenomSS; Oct 11, 2007 at 01:05 PM. Reason: Automerged Doublepost
Old Oct 11, 2007 | 01:09 PM
njg5gt's Avatar
it's your old car coming back to haunt you for getting another one....
idk man try getting the code and letting us know
Old Oct 11, 2007 | 01:11 PM
lol it told me 2 move on
ITS SAYING GOODBYE
Last edited by CobaltVenomSS; Oct 11, 2007 at 01:11 PM. Reason: Automerged Doublepost
Old Oct 11, 2007 | 01:56 PM
fr33k's Avatar
There's 4 different DTC's on the fuel level sensor.
P0461 Fuel Level Sensor Performance
P0462 Fuel Level Sensor Circuit Low Voltage
P0463 Fuel Level Sensor Circuit High Voltage
P0464 Fuel Level Sensor Circuit Intermittent
Old Oct 11, 2007 | 02:10 PM
well i always put 93 in it..should i try a different gas station?
Old Oct 11, 2007 | 03:16 PM
Novajoe's Avatar
you should try getting us the code so we can tell you what the problem might be...
Old Oct 13, 2007 | 01:41 PM
i finally got it checked out...they said its a cylinder misfire
Old Oct 13, 2007 | 01:42 PM
silentd's Avatar
time for new gas or plugs... are you running a step colder?
Old Oct 14, 2007 | 04:20 AM
bykryder83's Avatar
i have the same code po300 random multiple cylinder misfire wtf is that i have a 2.2 btw it would come on sometimes but tonight i put the cams in and its all the time i think its a bad o2 or something
Old Oct 14, 2007 | 10:54 AM
Novajoe's Avatar
can you give us the specific code? Is it a random misfire or a single cylender misfire?
On these car's it's impossible for a bad O2 to cause a random misfire. If there's an O2 code then it won't allow the P0300 to set.
You just replaced your camshafts... I'm guessing you mean aftermarket cams right? You more than likely need to make timing adjustments for them.
Old Oct 14, 2007 | 11:00 AM
rallyracer's Avatar
This started to happen to my old Cavalier...I never did figure out what the hell it was.
Old Oct 14, 2007 | 06:58 PM
bykryder83's Avatar
i had the code b4 the cam install
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
