Weird Sound...
Old May 13, 2007 | 10:50 PM
YellowG5's Avatar
Weird Sound...
After the G5 is warmed up, and I'm sitting at a stop light and it is quiet outside (usually at night) or I'm sitting in a drive thru, I hear this noise.
It sounds like a knock of some sorts, but it is only when the clutch pedal isn't pushed down and the trans is out of gear. When I hit the clutch it isn't there, and when I let the car idle in the parking lots or down my street in 1st or 2nd I can hear it too...and it is only there at idle, no where else in the rpm band.
Anyone got a clue as to what the heck it is?
Old May 13, 2007 | 10:57 PM
Coors's Avatar
Is it the "knock knock knock"?
There is a TSB out about it, it's the fuel pump, or something like that.
Old May 13, 2007 | 10:59 PM
kissmySS's Avatar
Evap canister i believe..
Old May 13, 2007 | 11:09 PM
YellowG5's Avatar
What would the fuel pump have to do with it only being at idle when the clutch is engaged? If the clutch is disengaged, then there is no knock.
Old May 13, 2007 | 11:11 PM
DoubleClutchin_ION2's Avatar
its the Evap can cleaning itself out
Old May 13, 2007 | 11:15 PM
YellowG5's Avatar
I have never heard of this at all on any car, Even my 04 sunfire with the Getrag 5 and ecotec 2.2 never did this...
Old May 14, 2007 | 12:10 PM
xtremeGM's Avatar
You cant compare your G5 to your past sunfire its not the same car. I have heard the noise you are talking about and thats what it is.
Old May 14, 2007 | 11:48 PM
YellowG5's Avatar
Dude, look at the cars much??? SAME EXACT MECHANICS, just different Chassis/Body/Suspension (hell even the suspension is almost identical except for a different spring rate)
My 04 Sunfire had the Ecotec 2.2L with the Getrag 5speed transmission. My 07 G5 has a 2.2 Ecotec with updated computer for the COP Ignition and a Getrag 5speed. Fuel delivery and all that is same.
If it is that, why does it only clean out when the clutch is engaged and either in Gear or N at idle? and Not disengaged?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
The Rookie24
Jan 20, 2016 05:14 PM
jcarroll53
Sep 24, 2015 07:43 PM
RyGuy
Sep 21, 2015 10:03 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
