weird spoiler noise?!
Old Apr 25, 2011 | 07:07 PM
DaBuzzard's Avatar
Originally Posted by Grishbok
lmao ok buddy, im not sure where I talked about F1 cars splitters, air dams, diffusers or spoilers, but you OBVIOUSLY are superior in your vast knowledge of aerodynamics, to the point you can't differentiate an airplane wing designed for LIFT with the rear wing on a car designed to produce DOWNFORCE.Comparing the two speaks VOLUMES about your competency in the field of aerodynamics.
A tip of the hat to you sir, i bid you good day.
Turn the wing over, your lift is now downforce.
Back to class Junior.......
Old Apr 25, 2011 | 08:13 PM
CobaltItaliano's Avatar
Yea had the same problem. Its fiberglass that broke off. Still ahve the noise to this day everytime I close the trunk. VERY irritating...
Old Apr 25, 2011 | 09:34 PM
06SS ALL DAY's Avatar
THANK YOU! lol
Old Apr 25, 2011 | 09:49 PM
donkeyballs's Avatar
The highrise spoiler doesn't do **** look under it and you will see a channel that runs along it and when it shakes in the wind that is also bad again not doing ****! If you filled the bottom and stiffened it up it would create alot more downforce.
Old Apr 25, 2011 | 10:27 PM
iisbalt: at 150 mph the high rise wing puts down an extra 182 lbs of force on the back tires.
This equates to 182lbs of weigh keeping the back in from coming loose at that speed.
Is it a requirment? Thats up to you.
Old Apr 25, 2011 | 10:37 PM
That would be like riding with a passenger..lol It doesn't do much but with a little work you would see huge gains. I don't care if it put 1000# of downforce it looks like **** IMO
Old Apr 25, 2011 | 10:43 PM
iisbalt: Is it a requirment? Thats up to you.
Old Apr 25, 2011 | 10:45 PM
Achilles's Avatar
Interesting, considering the spoiler is one piece .. it must be a manufacturer miscalculation.
Old Apr 25, 2011 | 10:55 PM
87gn06gto07irl's Avatar
ur really calling airplane wings junk... theyre suppose to flex. wow
Never said anything about the airplane wing. Don't know anything about that. But i do know that SS wings=junk. The downforce they do provide is from drag. Not a good design at all.
Old Apr 25, 2011 | 11:00 PM
Originally Posted by 87gn06gto07irl
Never said anything about the palne. SS wings=junk that supply no downforce and flap in the breeze.
That's not true.. They do but not much cause GM failed on design.
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Slick_Nick
Sep 28, 2015 09:15 PM
