what is the normal temp for a 2.2 ecotec
Old Dec 16, 2008 | 10:47 PM
rando's Avatar
i have a 06 cobalt and i find the cooling fan does not come on till the temp is around 110 celsius . i have changed the CTS sensor and the coolant is full.
can the pcm be set to turn the fan on sooner?
or is this a normal operating temp?
Old Dec 16, 2008 | 10:50 PM
D4u2s0t's Avatar
i don't know what theat means in celcius, but if it's under 230 fahrenheit you're fine.
we get these posts ALL the time from people that buy the car. the cars cooling is based on movement, and when sitting in traffic, or a drive through, it's normal for the temp to go way up pretty quick. should go back down once you start moving again though. in normal driving, it will probably linger somewhere around 190 or so.
Old Dec 16, 2008 | 10:52 PM
68nova200's Avatar
yea mine is always around 190* F goes down to 180*F when cruising on the highyway.
Old Dec 16, 2008 | 10:53 PM
D4u2s0t's Avatar
if it touches up around 230 in heavy traffic or when idleing for a long time, i wouldn't be too concerned as long as it goes back down after you start moving. if it's getting to that temp on the highway while cruising at 60, you have a problem.
Old Dec 16, 2008 | 10:54 PM
xCobalt05x's Avatar
i use to run at 189 all the time but now it runs at 190-212 depending if its stop and go or interstate
Old Dec 17, 2008 | 12:04 PM
Chad92's Avatar
110 is normal for the fan to come on. I wouldn't be concerned. My car runs around the high 80s, but with winter, the car is idling a little faster to help keep the engine warm, so it's sitting around 91, 92c. If you are really that concerned about it, go see your dealer about it.
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
jmelton327
Sep 26, 2015 10:04 PM
