Resonator Rattle
Old Dec 15, 2008 | 10:12 AM
Ducky22287's Avatar
Resonator Rattle
Is it ok if the resonator rattles a little bit? I just got a corsa touring and when I got it home I noticed when I moved it I heard I slight rattle, kinda like a couple pebbles in it. Any thoughts? Did I get screwed over?
I need an answer ASAP plz =/
Last edited by Ducky22287; Dec 15, 2008 at 10:12 AM. Reason: Automerged Doublepost
Old Dec 15, 2008 | 10:20 AM
Herndon_High_SS's Avatar
It shouldnt rattle.
Old Dec 15, 2008 | 10:28 AM
Ducky22287's Avatar
I jsut got off the phone with the guy, he said it's always done that but and I might hear a slight rattle untill the car warms up? Is this normal and is it gunna sound like ****?
Old Dec 15, 2008 | 10:54 PM
Ducky22287's Avatar
Wow, so first off I'm an idiot, it's the muffler part that rattles. So I was talking to a guy from corsa and he said there's no packing that should be loose but if part of the cat where to break off and enter the channels in the muffler then it could cause a rattle. Anyone had this problem and know a good way to get em out?
Old Dec 15, 2008 | 10:59 PM
That's what I meant if it was rattling there is something wrong. If ***** rattling in there you should be able to just turn the exhaust upside down and shake it out. But if your cat is breaking apart you need to get a new cat.
Old Dec 15, 2008 | 11:27 PM
Ducky22287's Avatar
Well I got it used so it was like that when I got it.
Old Dec 15, 2008 | 11:31 PM
JimzSS's Avatar
I had the stock down pipe ...
inards broke apart in the flex...
caused a rattle
convertor broke?
Old Dec 16, 2008 | 12:00 AM
Ducky22287's Avatar
That's what I'm assuming, can't think of what else it might be. I gotta try shaking it out but I have a feeling it's gunna be a lot harder than that sounds...
Old Dec 16, 2008 | 08:36 AM
Racerdad's Avatar
Are you sure it's not rubbing something somewhere? A rub will rattle, and can usually be fixed by bending the pipes a little. It's a big PITA to pull stuff apart like that...
Old Dec 17, 2008 | 12:30 AM
Ducky22287's Avatar
Na, exhaust isn't even on the car yet.
I'm having no luck shaking it out...anyone have a cut away pic or diagram with what the muffler section looks like with the channels?
Last edited by Ducky22287; Dec 17, 2008 at 01:56 PM. Reason: Automerged Doublepost
Old Dec 17, 2008 | 01:48 PM
ssboy05's Avatar
i have the same problem with my magnaflow exhaust and its my resignator thats shot. For $160 bucks i get a new one and have it installed in spring.
Old Dec 17, 2008 | 01:53 PM
Ducky22287's Avatar
I'm thinking if a piece of the cat broke and landed in one of the holes in the muffler section then it's just a matter of shaking it out...even though I've done it for 20 minutes today and no luck lol. Guess I gotta stay optimistic lol.
chefhhr
Oct 26, 2015 10:36 PM
jimbofug007
Oct 2, 2015 12:06 PM
Slick_Nick
Sep 23, 2015 08:07 AM
kcc140
Sep 15, 2015 02:14 PM
