wheel noise help
Old Oct 21, 2009 | 03:07 PM
chaydiddy3's Avatar
wheel noise help
So i have an 07 2.4 with 40,xxx miles on it. It recently started making a noise that seems to be coming from one of the front wheels. I cant really tell which. Sounds more like the passenger side. Sometimes the noise is louder than other times. It sounds almost like a helicopter sometimes. The noise is there when driving straight, seems to be worse when turning to the right, and is almost non existent when turning to the left. Also, it seems that some days the noise is louder than others. Just curious if anybody can give me some help or an idea on what the problem is. I donno if there's anything i left out. If you all need more info just let me know. Thanks in advance.
Old Oct 21, 2009 | 03:25 PM
roser4888's Avatar
To me it sounds like it could be your right front wheel bearing. Usually when they go bad and you are turning in the opposite direction of where the noise is you are taking pressure off that side the noise goes away.
Old Oct 21, 2009 | 11:18 PM
chaydiddy3's Avatar
thnx
Thanks for the reply. how can i check that to see if it is in fact the problem? And is it hard to fix? i know basics but that sounds like i may havta take it to a mechanic.
Old Oct 22, 2009 | 07:23 AM
roser4888's Avatar
Im not sure i dont think it be too hard
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
