when to change air filter and how
Old Jul 12, 2006 | 11:19 PM
hardtocope's Avatar
when is the normal milage for changing the air filter on the base cobalt? does anyone know how to change it?
Old Jul 13, 2006 | 12:42 PM
Novajoe's Avatar
I change mine every 10000 miles because of the dusty phoenix environment around here. Just check your filter evertime you change your oil(assuming you do it yourself, if not then when you take it in and have it done they will check your air-filter for you).
It's easy to change, just pop the intake box open(there will be several clips around the edges) then just lift the top off and change out the filter.
Old Jul 13, 2006 | 01:00 PM
Grimlakin's Avatar
How easy it is to change or check is very dependant on your model of cobalt.
If it is the SS/SC... I would let the people changing the oil handle it. Lol. Probably the dealership.
Why? You have to remove a wheel to change it or check it!
At least on my SS/SC according to the manual.
Old Jul 13, 2006 | 01:06 PM
LittleStealthSS's Avatar
Depending on who you talk to here... some say they've changed it without taking the wheel off, other not.
I'm more concerned about how us SS/SC guys are supposed to remove/replace the OIL FILTER... that thing is IN there....
Getting the OFL at teh dealership tonight, so I'm going to ask about how it's done. Once the car is out of warranty... I'm not paying that kinda scratch to have my oil changed.
Old Jul 13, 2006 | 03:00 PM
Grimlakin's Avatar
How much does your dealership charge?
Old Jul 13, 2006 | 03:09 PM
drdaley's Avatar
$62 - Fred Beans
Old Jul 13, 2006 | 03:18 PM
joeytroy's Avatar
For $62 they better wash and wax the ride too!!
Old Jul 13, 2006 | 03:19 PM
roccobladr's Avatar
my friend bought his mustang at fred beans.
Old Jul 13, 2006 | 03:21 PM
drdaley's Avatar
The first one was free and I saw on that it was $62. Not sure how much dealers really charge but at $62, I may change it myself.
What do dealers normally charge?
Old Jul 13, 2006 | 03:50 PM
RaineMan's Avatar
Spend $50 and buy a K&N drop in filter... then don't worry about it ever again.
Old Jul 13, 2006 | 04:06 PM
rnjmur's Avatar
On the SS/SC you don't need to take the wheel off to change the filter. If you take the screws out and the clips you can move the wheel well out of the way enough to get the air filter in and out. It is still a big pain in the ass though.
As for oil filter, it isn't that hard. 32mm socket and a 12 inch extension make it easy. The filter and cap come out underneath the SC (there is JUST enough room). Take the fileter off then put new one on, put it back through from under the SC and screw cap back on. It takes me about 3 minutes tops.
Old Jul 15, 2006 | 03:17 AM
Tomtwtwtw's Avatar
Exactly. I found it easiest to reach in and attach the socket to the filter cap first, then just plug the entension into that and twist. Once you loosen it a turn or two, you can do the rest by hand if it's easier. It's a little awkward at first, but once you do it you'll see it's not so bad.
Old Jul 15, 2006 | 04:38 AM
angie's Avatar
i would think any guy could changes his own oil.
no_ss
Oct 18, 2015 11:58 PM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
