Where is the outside temperature sensor located?
Yeah I was messing around with the windshield washer fluid connector and was yanking on wires to get the connector where I wanted it. I removed the drivers headlight and bracket, and put it all back, and no temp. So is the sensor in this area somewhere, or is it on the windshield?
u just answered your own question, if you messed with the headlight and bracket, chances are the sensor is loose or disconnected, yes, its behind the drivers side headlight.... not on the dash or base of the windsheild.............................
then what is that little yellow round circle???
and why would the put the temp senser behind a hot head light, with under hood temps???
Last edited by RACIN_RANDY; Oct 4, 2007 at 12:38 PM. Reason: Automerged Doublepost
Original Hayden Fanatic
what is the little yellow circle @ the base of the wind shield???
but a hot head light & under hood temps make for a better place to put that senser???
Last edited by RACIN_RANDY; Oct 4, 2007 at 01:04 PM. Reason: Automerged Doublepost
under hood temps are not going to go forward.
the sensor is ahead of the engine.
its also BELOW the "hot headlight", protected by the headlight bracket itself
it basically sits just above where your "cold air intake" sits....
are you talking about inside the car on the dash? That is the auto headlight sensor, it makes your headlights turn on when it is dark out...
Oh OK that sound better!! and mine I found to be the same 3°-4° diffrent, but do you know what the little YELLOW circle is, it's in the base of the wind shield.???
inside the car on the dash, close the the windshield?
do you have a pic, b/c i have no idea what you are talking about
I got no pic's, but it's at the base of the windshield, in the windshield, not in the car but in the windshield, I think it might be an alignment mark or something like that??? If anybody finds out please let me know, it's been puzzling me sence I just found out that it's NOT the outside temp senser.
time for a new windshield there bud
is that senser YELLOW??? NO!! is it IN THE WINDSHIELD??? NO!!! I know what that is I have to put a pice of paper over it to get the headlights to go on @ dusk time... I'll try to get a picture after work.
