white smoke
Old Jan 2, 2007 | 05:57 PM
blown07's Avatar
white smoke
i started my cobalt this afternoon pulled out shifted to second seen a large poof of white smoke or moistier when i hit the throttle thought well maybe cold to much raw fuel thir gear done it again is this normal on a cold ss/sc or do i need to have it checked
Old Jan 2, 2007 | 06:01 PM
D4u2s0t's Avatar
are you stock? if it was just a little bit when you started the car, dont' worry about it. If it's excessive, and thick, that's different... but a little puff on a cold start is nothing to worry about
Old Jan 2, 2007 | 06:04 PM
blown07's Avatar
im all stock didnt notice when i started it noticed when i built up boost
Old Jan 2, 2007 | 06:41 PM
NJHK's Avatar
Your car is racist...why does it have to shoot out white smoke? Why can't it be black smoke? Thats descrimination!
Old Jan 2, 2007 | 06:46 PM
D4u2s0t's Avatar
it's not discrimination!! the car just knows that white smoke is better than black smoke!
Old Jan 2, 2007 | 06:48 PM
G5GT2007's Avatar
i think thats normal. my G5 did that the other day. i hit the gas and my friend was behind me and he said he saw white some come out the muffler when i hit the gas. nothing to worry about i think.
Old Jan 2, 2007 | 06:50 PM
NJHK's Avatar
But everyone knows that black smoke is thicker than white smoke LOL
Old Jan 2, 2007 | 06:52 PM
D4u2s0t's Avatar
haha... can't argue that!!
Old Jan 2, 2007 | 06:55 PM
rally's Avatar
Technically "white" smoke is blue as far as actual smoke goes. But if its white then its moisture
Old Jan 2, 2007 | 06:59 PM
NVMYCOBALTSS's Avatar
At about 7100 miles, I had to have the head replaced. There was a defect that in a water jacket by the seam. When it was originally blasted to smooth the casting seam, the person or machine got a little thin. Keep an eye on your coolant level. If it starts to go down, take it to a dealer.
Old Jan 2, 2007 | 07:01 PM
NJHK's Avatar
Da Ladies love da black smizoke
Old Jan 2, 2007 | 07:47 PM
blown07's Avatar
i just got back from a beer run no smke on cold cranking
Old Jan 2, 2007 | 07:54 PM
Red07SSNA's Avatar
Were you in an "alcohol fog" and didn't really see any white smoke to begin with...
Old Jan 2, 2007 | 07:56 PM
blown07's Avatar
i wish it wouldnt bother me then
Old Jan 2, 2007 | 07:59 PM
blown07's Avatar
please leave comments i have to go watch a movie with the old lady any info would be greatly appreciated
Old Jan 3, 2007 | 09:36 AM
bc3tech's Avatar
ok... here goes - again.
white smoke, early startup, cold day = condensation in exhaust evaporating. you're actually seeing steam.
blue(ish) smoke, anytime = lean or indesperate need of an oil change!!! usually accompanied by knock followed by BOOM or *SIEZE*
black smoke, anytime = rich, you're ok but losing power like mad - get tuned.
Old Jan 3, 2007 | 09:43 AM
bigd2114's Avatar
with the black smoke one....tune or smaller pully
Old Jan 3, 2007 | 09:46 AM
Acidangel_5.0's Avatar
keep an eye on it.. if it speratic then whatever but if it is a continuin problem.. check your head gaskets.. you have a coolant leak somewhere then
Old Jan 3, 2007 | 09:56 AM
bc3tech's Avatar
yeah i s'pose that'd do it to... bottom line is you're rich and need more air
Old Jan 3, 2007 | 10:02 AM
D4u2s0t's Avatar
yea... i'm thinking it's just moisture.... like i said earlier, as long as it's not all the time, or extremely thick, i wouldn't worry about it so much... my car always smokes when it's cold out untill it's all the way warmed up... don't forget now that it's cold, your pipes are going from 20degrees to 200 degrees in a few minutes... when it starts warming up, the pipe collects condensation, and when it gets fully warmed it starts evaporating.... /end science class
Old Jan 3, 2007 | 10:30 AM
GOT BOOST?'s Avatar
Check your flux capacitor !!! Don't worry it is nothing just getting cold
Old Jan 3, 2007 | 09:52 PM
blown07's Avatar
i know about moistier but this was enough that i would call it a large amount any time i hit the throttle heavy it done it and it lasted for several blocks not just on craking and initial rev i have built a lot of hot rods in my day and i know all the basics i thought it my be where it was cold and it sent fuel to accomadate for the air sent by sc and couldnt burn the fuel or what i havent delt a lot with fi engines as far as sc and turbo so im not sure what is a problem and what isnt but i do respect all honest answers but i dont need to be talked to like a child please i understand the whole cold start up and moistier thing but this was enough to be a noticable cloud around the car behind me several bloks from where i started thanks
Old Jan 3, 2007 | 10:04 PM
blown07's Avatar
my last remark was left in reply to the one that begins with here goes again im not trying to offend but i understand the basics
Old Jan 3, 2007 | 11:09 PM
biohazard's Avatar
Get low
head gasket maybe.... if your burning coolent it will be white... would make sence that it happens whenever u boost, probably a small coolent leak into the cylender
Old Jan 3, 2007 | 11:18 PM
bc3tech's Avatar
the reason i said that is because i know for a fact this has been brought up on this forum before. searching ftw.
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
