Wierd problem
Old Jan 15, 2014 | 11:16 PM
05g5's Avatar
Exclamation Wierd problem
In the video i am crawling at 2-3 km/h feet off both pedals
ONLY does this when crawling, seems perfectly fine cruising, doesnt do this in reverse
Also slightly bucking or jerking each time the tach moves. Like i said everythingels seems fine, drives good
It also doesnt do this when cold, only after 30+ monites of driving
Edit #3 it seems my passive traction control is kicking in lots, at like 1-3k rpm when it shouldnt.
Wtf?
View My Video
Old Jan 16, 2014 | 09:18 AM
05g5's Avatar
alright, well that was a sucessful wasted trip down to my oil change place.
I ask for them to read my codes, cars acting up. Ok NP.
So this young girl hooks the scanner up, and says " thats your code right there, p0420 "
Im like " yea i know of that one, its says 01/02 in the top corner, whats the other one? "
Well, not before she already had her finger on AND presses the CLEAR button, and she just gives me this blank OH **** look.
Im like " .... thanks, i got a buddy up the road with a scanner, ill have to wait for it to pop up again "
on a side note, the manager there said he had the same issue with his cavi, and it was water corroded some wires / sensors & he took it in to get fixed. not really an option for me, as im stubborn. ill figure it out and fix myself ( and with your help )
Old Jan 16, 2014 | 09:45 AM
05g5's Avatar
the only thing google has led me to is, like 90% of people that have this problem, either A: their gas pedal stops working or B: the tranny doesnt shift.
and the speed sensor on the tranny goes.
guess i look at the sensor on the tranny
Old Jan 16, 2014 | 10:49 AM
05g5's Avatar
hopefully i just fixed it, i found a pretty dam big ground wire that bolts onto the vavle cover, a thick woven one. i guess when i was doing a little TLC thsi past weekend i forgot to connect it again.
no time to test atm, dam night shifts & i need sleep. will post tonight if it fixes or not
Old Jan 16, 2014 | 01:35 PM
05g5's Avatar
Nope not fixed
Ffs
Old Jan 16, 2014 | 05:34 PM
05g5's Avatar
Nyone have an idea which sensor will cause my speedo on cluster to act up and possibly cause car to surhe or buck?? Input or output
Old Jan 16, 2014 | 10:12 PM
05g5's Avatar
Well i think its safe to say now after 5 hours of driving and 4.5
Of them being problem free ( first 30 min was a pita )
But the speed sensor on te tranny, passanger side of the car! I sensor wire CASING was lost or ripped off from god knows when, and it was rubbing pretty well bare wire onto a hot tranny bracket . And clearly was shortyinf out. I cleaned it up, taped it, took the connector apart and cleand that aswell.
Problem free, im clearly a choosen one wih such a simple solution to this pita problem hahah
Old Jan 16, 2014 | 10:18 PM
05g5's Avatar
This is a pic of the wire colors, where it is ( below the water pump ) and the connector piece i cleaned
Problem solved( for anyone that might stumble upon this in the future, check the wires first!!! Clean the connectors !!)
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
