Wire (line) by back left wheel well
Old Aug 3, 2011 | 07:16 PM
Estela's Avatar
Does anyone know what the wire is called by the back left wheel well? I have a 2006 SS, it's held to the bottom of the car by a blue clip. This clip fell out of its place and the wire was rubbing on my tire. The rubber coating of this wire was worn off in a section and it exposed what looks like a metal wire. Anyone know what this is? Would I be able to put electric tape on the piece of rubber that rubbed off?
Thank you!
Old Aug 3, 2011 | 07:21 PM
rogersj's Avatar
your better off cutting it join it with a insulated butt connecter and cover it with a tube of heat shrink and then tape it. using tape by itself will let water in and after time the wire will rot away.
Old Aug 3, 2011 | 07:27 PM
Coblasts's Avatar
The wire is probably for your wheel sensor for ABS ,donot cut it.If you do it will have to be soldered and still might cause an issue.
If there isnt any problem yet cover it with silicone for water resistance and tape it up well.
Old Aug 3, 2011 | 07:44 PM
C_A_D88's Avatar
By the sounds of it it's your ebrake cable
Just saying
Old Aug 3, 2011 | 09:41 PM
Coblasts's Avatar
Just saying
X2
Never thought of that ,but it is more of a cable then a wire.
But yes it would be silver under the coating and they would be spirals about 3/16 wide.
Old Aug 4, 2011 | 02:38 PM
DaBuzzard's Avatar
Originally Posted by Coblasts
X2
E brake cable for sure. As long as you haven't worn through the spirals (conduit actually) just tape over good to keep the moisture from getting in and corroding stuff.
Old Aug 4, 2011 | 09:18 PM
C_A_D88's Avatar
I just did my rear disc conversion, so I know that's the only thing held on by a blue clip back there lol
chefhhr
Oct 26, 2015 10:36 PM
How to Guide
57
Oct 15, 2015 11:56 AM
Turbo6
Sep 24, 2015 04:15 PM
Cptnslo
Sep 24, 2015 09:32 AM
Jeffwills14
Sep 6, 2015 06:52 PM
