Wiring gauges
Old Mar 8, 2011 | 03:53 PM
CTcar's Avatar
Wiring gauges
So I just bought an AEM wideband gauge to go with my stock boost and interceptor. When I wired the interceptor I tapped power off the pink boost gauge wire, and both worked fine. Now I added the a/f gauge and tapped power and ground off the same boost harness. When I turn the key on the interceptor works, the a/f shows 111 (not hooked to sensor yet and car isn't running) and the boost gauge doesn't work. Clearly the other 2 are getting power, so i unplugged the a/f and interceptor to see if they were causing any issue, and he boost still doesn't power on.
Also I noticed a weird noise coming from the boost gauge when power is on.
Any help would be great!
Old Mar 9, 2011 | 11:35 PM
CTcar's Avatar
Old Mar 10, 2011 | 12:04 AM
xnigelx's Avatar
Google
is what you should have used u might be messing up the voltage.. there is plenty of fuses in the box next to your radio
disconnect both gauges and see if your boost gauge works
Old Mar 10, 2011 | 07:56 AM
CTcar's Avatar
Originally Posted by xnigelx
Google
I did disconnect the other ones and just try boost gauge, still nothing. I'm leaning toward it might be busted.
Old Mar 10, 2011 | 08:10 AM
xnigelx's Avatar
its possible. luckily boost gauges are cheap. id say wire your aem into and wire your aeroforce into the fuse panel ive had my aem hooked up to my boost gauge with no problems but soon as you add another gauge it might have jacked it up. when u added this gauge you did have your battery disconnected right?
Old Mar 10, 2011 | 11:30 AM
CTcar's Avatar
I wired the whole thing off my car unplugged. My buddy is bringing over a test light and voltmeter tonight.
Old Mar 10, 2011 | 08:42 PM
CTcar's Avatar
Got it fixed! Bad ground connection, even after I re-did the connection it still didn't work right, 3rd time was the charm
Old Mar 10, 2011 | 08:52 PM
overboostedss's Avatar
2 be honest I would really wire ur other 2 gauges off a seperate power source. That's a lot to be drawing off the boost gauge harness u don't wanna fry it. Take a male connector and grind it down it will plug right into 1 of the extra terminals in the fuse box. That's what I did.
Old Mar 10, 2011 | 09:06 PM
CTcar's Avatar
I think I'm going to get one of those add a fuse things, right now I'm just glad they all are working lol
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 07:39 AM
Sep 27, 2015 08:53 PM
