Wtf brake problems
Wtf brake problems
I am trying to figure out what I am doing wrong. I swapped clutches and am now having major problems. I have bleed the brakes like 5 times and the clutch like 4 times. I cant get the brakes to work at all. I do know how to bleed brakes and I vacuum bleed the clutch. The clutch goes in gear while on in all gears but reverse. Can someone tell me if there is a trick in bleeding these brakes or is something just broken in my brake system?
I was under the assumption, thats the brakes and the clutch are actually the same system.
I would look to the advice of the gm build book, chapter 5 and 6, im sure i read the bleed procedure there. lemme find a link for you.
here ya go:
http://www.gmperformancedivision.com...SJ_Chap5&6.pdf
here ya go:
Last edited by shaunmcdee; Jun 16, 2007 at 03:05 PM. Reason: added supporting link
