youve got CEL!!!!
Old Dec 22, 2007 | 01:56 PM
jeffinHD's Avatar
youve got CEL!!!!
hey guys i know theres to many threads on intake but nobody is responding ...anyway i got a question for you. i installed my ebay CAI today and it runs like **** for like 10 mins then its fine. it will idle rough (rpms up and down)I do have a CEL , i keep my engine very clean and everything is hoked up coorect way ... do i need a new mass airflow sensor or somthing ,whats wrong? please help
:cuss ing:
Old Dec 22, 2007 | 01:59 PM
jamiep101's Avatar
you may have damaged the mass air flow sensor or got it wet or something go back and make sure you did everything the right way when u installed it
Old Dec 22, 2007 | 02:27 PM
red07g5's Avatar
Did you unplug the battery? Try leaving it unplugged for a while.
Greased's Avatar
i think you can clean the MAF w/ rubbing alcohol dont take my word for it tho check some other threads on this
Old Dec 22, 2007 | 02:30 PM
JohnnySasakiMGS's Avatar
Go buy some mass air flow sensor cleaner. It comes in an aerosol can. Unplug your negative battery terminal also. If that doesn't work then I suggest you return the item and buy another intake. Don't buy an ebay intake.
Old Dec 22, 2007 | 02:37 PM
jeffinHD's Avatar
no i didnt unplug the battey yet, ill try that. and yea i know i should have bought the better intake but i dont think theres that big a differnce between them. i mean its just a pipe
Old Dec 22, 2007 | 04:18 PM
It is just a pipe and a filter yes. But is that filter letting too much or too little air in? Is it designed correctly to have the MAF sensor in the correct position in the tube? Try scanning for the code to see what exactly is wrong.
Old Dec 22, 2007 | 04:26 PM
Witt's Avatar
Definetely have the code scanned to see what the PCM is saying.
The usual cause of a check engine light after an aftermarket intake pipe installation is because of the change in pipe diameter of the new intake, easily fixed by anyone local who is able to recalibrate your mass airflow sensor via HPTuners.
That really doesnt make any sense. A mass airflow sensor measures actual air mass, hence the name.
Old Dec 22, 2007 | 04:31 PM
recklessactn's Avatar
dont flame me for askin but i just installed a new injen cai and the car runs fine, but i didnt disconnect the battery after the install. should i disconnect and reconnect anyways just for the heck of it?
Old Dec 22, 2007 | 04:46 PM
Witt's Avatar
Don't worry about it. The car will learn new fuel trims at the same rate regardless of whether its memory was reset or not.
Usually pulling the battery will take longer for the car to run the way it did before because now it has to also relearn other stored variables that the new intake didn't affect.
Old Dec 22, 2007 | 04:51 PM
ahh ha, thanx man
Old Dec 26, 2007 | 12:58 AM
jeffinHD's Avatar
yea i cAN do that ill scan them tomarrow
Old Dec 26, 2007 | 01:01 AM
Super_SS's Avatar
the MAF sensor isnt reading the right amount of air hitting it..all the air goes around it and not into it..so it throws a code and pops the light to let the driver know that its not reading any air,altho **** load of air is passing around it and goin where its suppose to go..its just giving u an annoying heads up
Old Dec 26, 2007 | 12:18 PM
jeffinHD's Avatar
so if this is our problem how can i fix the sensor so it reads correctly?
Old Dec 26, 2007 | 03:09 PM
Novajoe's Avatar
if you have an ss/sc you can find someone with hp tuners to tune your MAF sensor for the change.
It would probably be cheaper to ditch the cheap intake and get one that's the right diameter though. MAF tuning can take a good amount of time on the dyno sometimes. Time=money.
Old Dec 26, 2007 | 03:37 PM
rukkee's Avatar
If the intake narrows down on the end going into the filter you need to cut that piece off . A lot of people were having cel issues with ebay intakes , after they trimmed the end off their problems dissappered .
Old Dec 26, 2007 | 10:18 PM
jeffinHD's Avatar
OK i did a scan at work and if i remember correctly the code was p0844 there was no description of that code. i also checked every conaction and cleaned the MAF sensor. also i cleared the code but i just came back again and car is running like **** again. im relly pissed now so any help is mucho apreciated
if the answer is hp tunners how would i go about find a person/shop that could help?
p.s. i did not disconnect battery, and when i was working on it notice quite abit of liquid comming out of the tailpipe.
Old Dec 27, 2007 | 08:27 AM
rukkee's Avatar
P0844 isn't on the DTC list for the 2005- 2007 cobalt , theres a p0843 then i jumps to P0961 according to GM's service information current list .
read this
https://www.cobaltss.net/forums/show...ht=intake+ebay
Old Dec 27, 2007 | 09:43 AM
Novajoe's Avatar
http://www.aa1car.com/trouble-codes/codes_899.htm
P0844....Transmission Fluid Pressure Sensor/Switch 'A' Circuit Intermittent
Old Dec 28, 2007 | 01:16 PM
rukkee's Avatar
Huh... thats weird that GM doesn't have it in service information under DTC list. Maybe i'm wrong but why would a 5 speed have a Transmission Fluid Pressure Sensor?
Old Dec 28, 2007 | 01:45 PM
jeffinHD's Avatar
ok heres he deal i have no idea where that code came from ...it was actually p0833 but its not giving it anymore now i just get 2 codes p0101 and p0103 there both MAF codes......any ideas?
Old Dec 28, 2007 | 10:14 PM
jeffinHD's Avatar
Old Dec 29, 2007 | 05:25 AM
rukkee's Avatar
P0833
Clutch Pedal Switch 2 Circuit
Did you read about cutting the end off the intake??
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/ebay-intake-installed-61845/
Old Dec 29, 2007 | 02:56 PM
Witt's Avatar
It sounds like the MAF is disconnected. A poor connection will cause p0103 to set. P0101 is setting basically because p0103 is.
If its setting the code at anything other than near redline (idle or cruise mainly) its probably the connection. It could be something else like a faulty MAF or you actually are hitting the MAF limit but the connection is easy to diagnose.
Old Dec 29, 2007 | 03:30 PM
Sizzle06's Avatar
Just try what rukkee said,the ebay intake has a bottle neck at the end of the pipe where the filter goes.Cut that piece off and you should be set,i was getting the same code until i cut that piece off,good luck.
Forgot to add,ditch the ebay filter if your using it and buy a aem dryflow filter.
