ZZP Exhaust tip melting bumper
Old Jun 5, 2013 | 10:17 AM
Bl4des's Avatar
has anyone else with zzp exhaust had the bumper melted by the exhaust tip. i am furious right now. this is my 3rd exhaust, i have had magnaflow and hahn and never had a problem.
i don't know why the exhaust tip it welded on a slightly upward angle. i am going to mess with it some to try to get it to stop melting it more and now i need to have my bumper fixed.
Old Jun 5, 2013 | 10:36 AM
Curious why you've switched exhausts? all 3 inch im assuming? I know you just came from Hahn correct?
Old Jun 5, 2013 | 10:39 AM
Bl4des's Avatar
yeah i really just changed because i didnt want to cut the hahn up to take the resonator out and i had to buy a new downpipe so i just got a new exhaust from turbo back
and yeah all 3in
Staged07SS's Avatar
Administrator
Administrator
Try adjusting the hangers.
Also, you can pick up rubber grommets from Advance Auto and slide them onto your exhaust hangers to help adjust/secure the rubber hangers. This will help move the tip over so it stops resting against the bumper.
The downpipe I run on my car caused my catback to move slightly to the left when looking at the rear of the car. I wanted to center the exhaust, so I installed the rubber grommet I mentioned, and it moved the exhaust back over center.
Worked great!
Old Jun 5, 2013 | 10:53 AM
Bl4des's Avatar
it has nothing to do with the hangers you can see it in one of the pics that they are not even up and down they are on an angle.
it is the fact the exhaust tip is not welded to the muffler right.
Old Jun 5, 2013 | 11:04 AM
Twoozofjuice's Avatar
Oh hi...
Old Jun 5, 2013 | 11:08 AM
SalvageBaltSS's Avatar
man that sucks. i have my stock tip adjusted tucked up by the bumper and dont see signs of this happening .
Old Jun 5, 2013 | 11:10 AM
Bl4des's Avatar
look at that not the only one. that is a zzp right
have you ever contacted them about it
Old Jun 5, 2013 | 11:14 AM
No I haven't talked to zzp about it. What are they gonna do get me a new bumper? lol. And this one is the 2.5 inch
Old Jun 5, 2013 | 11:19 AM
Bl4des's Avatar
yeah if it is there fault they should have to have it fixed and any damage they cause fixed
if there wasn't an upward angle on the muffle tip there would be no problem and the catback would fit great.
Old Jun 5, 2013 | 11:22 AM
Yeah I really really doubt that. But if you contact them and they send you a bumper let me know and i'll have to send them a email also haha
Old Jun 5, 2013 | 11:38 AM
breds2k's Avatar
If you didnt have a shop put it on they will 100% say install error!
Old Jun 5, 2013 | 11:41 AM
Bl4des's Avatar
i have 2 associates and 1 bachelor degree in automotive
i don't need a shop
Old Jun 5, 2013 | 11:45 AM
I don't understand how you can put a exhaust on wrong....
Old Jun 5, 2013 | 11:46 AM
BLAZIN07SS's Avatar
I'm too JDM for you
then why would you leave it installed like that mr.university? I hate when people throw their degrees out when they do something stupid
Old Jun 5, 2013 | 11:49 AM
Bl4des's Avatar
i didnt leave it like that it moved when driving. i move it back so it is not touching anything hopefully it stays this time. it didnt melt it to bad, wont be hard to fix it when i have time to
Old Jun 5, 2013 | 12:00 PM
DarkChild's Avatar
My ZZP 3" exhaust did the exact same thing as the OP's pictures. I'm replacing it.
Old Jun 5, 2013 | 12:02 PM
Staged07SS's Avatar
Administrator
Administrator
Remove it and send it back then....
Old Jun 5, 2013 | 04:20 PM
MyOtherSS's Avatar
the only zzp catback I've seen in person did this same thing.
Old Jun 6, 2013 | 05:42 PM
Bl4des's Avatar
Adjusted it so it didn't touch and went for a 5 min ride and it went right back to were it was melting my bumper
Old Jun 6, 2013 | 05:49 PM
Bl4des's Avatar
It's not like I have different company part I have all zzp exhaust from the turbo mani back and net even one of the exhaust hangers lines up right I am really regretting getting rid of my Hahn exhaust now
Old Jun 6, 2013 | 06:05 PM
SPDDMN36's Avatar
My brother has the same issue with his. Just added more hangers to hold it in place.
Old Jun 6, 2013 | 06:07 PM
cOHbalt's Avatar
Oh jeez I am about to order a 2.5
Old Jun 6, 2013 | 06:10 PM
Bl4des's Avatar
I am going to try to adjust it more if I can but this is the worst flitting out of magnaflow hahn and zzp
Old Jun 6, 2013 | 06:33 PM
Add gmpp to that list^
That's what I had on before and it fit perfectly. Never touched my bumper. Install this and on the first day I torch my bumper. Moving it around did nothing.
