R1 Concepts R1 Concepts is a Supporting Vendor.
Contacts: r1concepts
R1 Concepts| PREMIER SERIES ROTORS & BRAKE PADS (*NEW PRICING!*)
Old Jun 14, 2016 | 07:22 PM
r1concepts's Avatar
R1 Concepts is proud to offer Premier Series Rotors!
R1 Premier rotors provide the ultimate stopping power needed for demanding driving and harsh conditions. Manufactured using more Carbon, Chromium, and Molybdenum, these high carbon rotors offer increased braking performance and strength. A center split core casting design provides greater stability. Black Electro Coating protects against rust while extending rotor life. Mill balancing and double disc grinding reduces thickness variations for smoother stopping, minimal vibration, and improved break-in. All R1 Premier rotors are designed for direct fitment; no modifications are required.
What separates R1?
Here at R1, we take into account numerous precautions in machining rotors. We drill our rotors in house using state-of-the-art CNC machines and follow strict procedures and standards such as drilling between each vane structure. This will allow the rotor to retain its structural integrity and overall strength with optimum thermal transfers. We utilize smaller diameter drill bits for smaller diameter holes and each hole is counter-sink to add strength. You also have the option to go with slotted only or even a custom design with your own logo. Every R1 rotor that comes with slots will come with our Diamond Slot design (45 degree angle end points), to help release trapped debris. Our diamond slot design is also a good indicator for rotor wear.
Warranty
Here at R1 Concepts, we stand by our products. We offer a one year warranty on warping and cracking on all R1 brake rotors due to manufacture defects and workmanship.
Drilling Patterns
Dimpled & Slotted
Drilled & Slotted
Dimpled
Slotted
Drilled
FT/RR PREMIER SERIES ROTORS
05'-08' COBALT SS 2.4L SINGLE PISTON FRONT CALIPER & SS 2.0L SUPERCHARGED BREMBOS : $290 SHIPPED
08'-10' COBALT SS BREMBO FRONT CALIPERS W/ VENTED REAR DISC: $300 SHIPPED
BRAKE PADS
FT/RR POSI QUIET CERAMIC BRAKE PADS (05'-07' SS 2.4L SINGLE PISTON): $80 SHIPPED
FT/RR POSI QUIET SEMI-METALLIC PADS (BREMBO FRONT CALIPERS): $90 SHIPPED
FT/RR HAWK HPS BRAKE PADS (05'-07' SS 2.4l SINGLE PISTON): $115 SHIPPED
FT/RR HAWK HPS BRAKE PADS (BREMBO FRONT CALIPERS): $180 SHIPPED
BRAKE FLUID
STOPTECH STR-600 (500mL): $16
STOPTECH STR-660 (500mL): $24
CONTACT
Kevin C.
Kevin@r1concepts.com
888.712.6623 ext .7022
Old Jun 16, 2016 | 08:07 PM
r1concepts's Avatar
Old Jun 21, 2016 | 08:30 PM
r1concepts's Avatar
Old Jun 23, 2016 | 08:52 PM
r1concepts's Avatar
Old Jun 24, 2016 | 08:51 PM
r1concepts's Avatar
Weekend bump
Old Jun 27, 2016 | 08:31 PM
r1concepts's Avatar
Old Jun 29, 2016 | 09:09 PM
r1concepts's Avatar
Old Jul 1, 2016 | 08:39 PM
r1concepts's Avatar
Old Jul 6, 2016 | 07:30 PM
r1concepts's Avatar
Old Jul 8, 2016 | 09:10 PM
r1concepts's Avatar
Weekend bump
Old Jul 12, 2016 | 08:57 PM
r1concepts's Avatar
Old Jul 14, 2016 | 06:33 PM
r1concepts's Avatar
Old Jul 19, 2016 | 09:05 PM
r1concepts's Avatar
Old Jul 19, 2016 | 11:14 PM
Ran these when i owned my TVS cobalt. many times breaking past 140mph ( in mexico of course ) never had issues. painted hats and rotor edges were huge in keeping the rusty look out. service was excellent
Old Jul 21, 2016 | 09:14 PM
r1concepts's Avatar
Old Jul 22, 2016 | 08:45 PM
r1concepts's Avatar
Weekend bump
Old Jul 23, 2016 | 06:57 PM
SR Tech's Avatar
What's the difference between these rotors and the ones I bought from your last year? And what's the price for just a front set for the lnf?
Old Jul 25, 2016 | 05:51 PM
r1concepts's Avatar
If your purchased our Premier Series rotors from us last year, then this is the same rotor. We just wanted to create a new thread to separate my Premier and E-line Series rotors.
Old Jul 26, 2016 | 09:18 PM
r1concepts's Avatar
Old Jul 28, 2016 | 09:24 PM
r1concepts's Avatar
Old Jul 30, 2016 | 05:36 PM
r1concepts's Avatar
Weekend bump
Old Aug 2, 2016 | 09:08 PM
r1concepts's Avatar
Old Aug 4, 2016 | 08:22 PM
r1concepts's Avatar
Old Aug 9, 2016 | 09:33 PM
r1concepts's Avatar
Old Aug 16, 2016 | 09:08 PM
r1concepts's Avatar
