Rev It Up Motorsports Rev It Up is a proud Supporting Vendor
pulley kit now available. call us to order
Old Aug 25, 2005 | 03:52 PM
Tedro's Avatar
How many wires are thier to tap into for the piggyback, where are the wires located? I would be sweet to have an actual piggyback plugs that the stock plug connectors that you can just connect inline with the factory harness like I have installed before like billydog does. That is all
Old Aug 25, 2005 | 04:07 PM
ray@revitup's Avatar
there are about 8 wires connected to the ecu wires. the ones i install for a couple of extra bucks i can make it so the we can unplug it whenn needed
Old Aug 25, 2005 | 05:26 PM
Maverick's Avatar
Great news! I live in south jersey too!
1. Does the car still run very rich?
2. Does this reduce gas milage by much?
3. Do you still have to replace the boost gauge with a mechanical one to get a true reading?
4. Is the CAI issue fixed?
5. You said someone made 245hp, what are the torque numbers?
6. Video, or dyno sheets soon!?
Thanks!
Old Aug 25, 2005 | 11:14 PM
06black's Avatar
Originally Posted by ray@revitup
the same
if we buy the kit would you be willing to help guide me thro the instal to help save some money? also is the instal hard or does it require any special tools? thanks for any help.
Old Aug 26, 2005 | 12:58 AM
Eddie's Avatar
this would be one of the first things i'd purchase if/when i purchase an ss s/c
Old Aug 26, 2005 | 01:26 AM
SS4LIfe's Avatar
i will be there this weekend to get it installed do you offer free dynos
Old Aug 26, 2005 | 03:28 AM
MacG321's Avatar
does the piggyback stop the car from problably throwing every code imaginable?Do you have to change the plugs to help support more boost? If you put this kit on a stock ss, what will its #'s be on the dyno?
Old Aug 26, 2005 | 09:14 AM
a pulley puller is required
Old Aug 26, 2005 | 09:16 AM
no, if there is something wrong with the car it will throw a code. however you woill not get anycodes from the piggyback or from cranking up the boost. you can also install aftermarket air filters.
i can install one sunday of you want no free dynos
Old Aug 26, 2005 | 09:23 AM
  #36
that is a members dyno with this kit, he had no torqe numbers
Old Aug 26, 2005 | 09:36 AM
  #37
we have seen power gains from 25- 35 whp increase at the wheels
tourqe numbers increase 50 lbs at the wheels
the thing we have notice is all cobalts are different as far as how much ower they are making from the factories, plus dyno numbers vary from one dyno machine to another. so figure an increase of 25-35 whp over your stock numbers and about 50 lbs of torque all at the wheels
Old Aug 26, 2005 | 10:12 AM
  #38
SS4LIfe's Avatar
is this sunday good for you, and do you offer warrenty with the work, and if something better comes out like a AFC or something could we just disconnect the piggyback.
thanks and if sunday is good, i'm there
Old Aug 26, 2005 | 12:17 PM
  #39
Kiss My SS's Avatar
did you have to grind out anything to fit the larger tensioner?? if so could we just go with a smaller pulley belt?
Vinny
Old Aug 26, 2005 | 02:04 PM
  #40
theBLUEone's Avatar
Where exactly are you located?
Old Aug 26, 2005 | 02:14 PM
  #41
glockglade's Avatar
Hey very interested in purchasing one of these in the near furture but before i purchase I would like to know if the air fuel ratio is still rich throughout the powerband with the smaller pulley sytem and piggyback, and any little things during installation you will need that is not included with this package. Thank You!! Keep the products coming!
P.S. Will a spark plug change be necessary, if so what plugs do you recommend for this application and what gap?
Old Aug 26, 2005 | 02:15 PM
  #42
silverSS's Avatar
what gear was the pull in that dyno?
Old Aug 26, 2005 | 02:36 PM
  #43
Vinny
we could not find a smaller belt that was the same strength as our stock one we just grind a lil bit
Old Aug 26, 2005 | 02:37 PM
  #44
3rd and for some of the numbers we also did 4th
Old Aug 26, 2005 | 02:38 PM
  #45
im in rockledge outsside of northeast philly
Old Aug 26, 2005 | 02:40 PM
  #46
the car is tuned perfect with the pulley kit, and is runing at a safe afr level. you will need a puller tool and soilder
Old Aug 26, 2005 | 11:04 PM
  #47
carbombss's Avatar
will this piggyback correct the boost gauge not reading the actual boost u r pulling
Old Aug 27, 2005 | 12:25 AM
  #48
Shermen's Avatar
how long before you put it on your website? (like im waiting that long anyway) but j/w
Old Aug 27, 2005 | 12:47 AM
  #49
SS4LIfe's Avatar
come on
Old Aug 27, 2005 | 10:11 AM
  #50
Kiss My SS's Avatar
can you sell the extra plugs that you would but in so its an easy on and off. cause i really don't want to drive to philly from new york?
