SCdyne SCdyne is a proud Supporting Vendor
1/8" thick RemFlex Gaskets
Old Jan 10, 2006 | 06:56 PM
SCdyne's Avatar
Rem Flex is going to make both the Head flange and Exhaust flange gasket based on a drawing that we're sending to them either tonight or tomorrow.(depends on when I get home) Once they get the 'OK' it will be 5 days to produce the first one to test fit and after that I'll have them available for sale. (I'm purchasing a good number of them to get it started)
Since a lot of people question my motives I didn't ask for exclusive rights to the gasket tooling and I changed the design to a more generic profile so anyone will be able to purchase a gasket from RemFlex to work with any ECOTEC engine once they are available.
These gaskets are 1/8” thick and compress 50% so this should take care of any leaks at both flanges. Also they rebound 30% so the chances of time causing a leak from movement will be unlikely. It’s not a group buy or one time deal they will be available as soon as the tooling is completed.
Just understand that even compressing down to .0625” will add a bit of space between the head and header. The same holds true for the exhaust gasket and it will have a 2.75” ID and no larger. The TOG header is a little more than 3.0” opening, but the exhaust pipe is only 2.5”. I needed to do this so there is enough material between the 2 flanges to be safe and guarantee a good seal. The combination of the 2 gaskets could possibly cause interference issues with the header and sway bar under certain conditions or other unknown fit problems, but for the most part it should work.
Turbo Johnny
Feb 21, 2019 09:41 AM
Spanky's Monkey
Mar 7, 2016 06:06 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
RedLined
Sep 9, 2015 09:11 PM
