Best way to clean engine compartment..?
Hay guys just a quick question that I was not able to find in a search.. is there a best way to clean the engine compartment out and make it look better/cleaner.. use water/air ideas..? Simple question but looking for best results..
what???
i hope to god you cover all you non-water safe electrical components such as your alternator...
as for the question that started the thread, they sell engine cleaner at any auto parts store it works perfect- it's a degreaser- works like a charm!
as a detailer... I use a pressure washer and do the engine bay around other 2 washes... and i use an air gun to blow out all the water from everywhere. i don't really cover stuff up unless everythings really dirty then yeah butnot usually. I also usually spray the under neath of the car also... and about once a month or so i take the wheels off and get the brake dust off them..
WTF! a power washer wont hurt the altenator, i use the power washer all time never had a prob.
Well did you ever hear a squeaky blet? hmm water can get into the pulleys bearings and screw them up... it can screw the coils up... it can screw the alternator up... it can prolly screw the fuse box up but i've never scene that one happen... so it can def. fck sht up
Lets get one things straight... If your filtering your water you will not have anything to worry about. Pure water does not conduct electricity nor does it cause corrosion. So... power washing the car then just do a "spot free" rinse.
EDIT: Just be careful of greased componants, power washing them might end up something other than a shinny apperance.
patooyee
Oct 1, 2015 01:07 PM
