Show & Shine Detailing, washing, waxing, paint care, wax, etc.
Major overspray
Old Apr 13, 2008 | 11:45 AM
rockSTAR_SS's Avatar
Major overspray
So I got my car back from paint last week and when I was waxing the car this past friday I noticed that the hood is simply covered with over spray. Like...you see the line where the paint man tapped it off. It's all glossy and shiny and amazing but then you see where the overspray starts. It's a turn off... Not only is it on the hood but I can rub the fenders and find overspray and on the back windshield... Go pimp slap the paint man or is there anything as far as wax or cleaning chemicals I can use to get this mess off?
I was using plain old turtle wax to shine the car up a bit before I went out for the weekend but it didn't even try to take it off... I'd rather not wet sand it unless I absolutely have to. Last time I wet sanded a car with 2000 grit paper I screwed the clear coat all up removing the yellow paint they spray for road lines...
Old Apr 13, 2008 | 12:49 PM
takes5tries's Avatar
take it back to the paint shop, have them fix it for free
Old Apr 13, 2008 | 12:50 PM
icemaid's Avatar
Yup, take it back and they will clean it off.
Old Apr 13, 2008 | 12:52 PM
Kritter's Avatar
Slap your paint guy, and make him buff the whole damned car......After I got my car out of the shop, I took it back 3 times for overspray, then I found it again on my decklid, but gave up on the dealer, and am just gonna have someone buff the whole car for me
Old Apr 13, 2008 | 12:56 PM
D4u2s0t's Avatar
i would take it back to whoever did that. they should fix it for you for free.
Old Apr 13, 2008 | 01:39 PM
Nortybignort's Avatar
If you are going to do it yourself a claybar should be able to take it off unless its real bad.
Old Apr 13, 2008 | 01:43 PM
Pully Police's Avatar
^ Yes...claybar. DO NOT TRY TO BUFF IT OFF! You will marr the hell out of your finish. just take your time, try not to use a claybar that is too aggressive (coarse) on the finish. It should come off with no problems.
Old Apr 13, 2008 | 01:44 PM
devon9832's Avatar
I wanna see the severity of it. any pictures?
Old Apr 13, 2008 | 01:46 PM
boostedss26's Avatar
come one now dont slap the painter i am a painter lol, You can wither buff it off, clay bar, or use laquer thinner. If i were you i would just bring it back and make them do it you should never have overspray on a customers vehicle.
Old Apr 13, 2008 | 01:47 PM
sschevy25's Avatar
i agree with the part of taking it back to the shop...they should fix that if they are a reputable shop...know this because i had issues after i got mine back...i took it back and they fixed the problems...nothing major..but just what i went through
Old Apr 17, 2008 | 08:55 AM
Chris(NJ)'s Avatar
2nd. Clay should remove it. A mild clay usually works, however, if its really bad, a more aggressive clay may be required. It will leave some slight marring however, so it would need to be followed by a polish to remove that.
http://www.glimmerglassdetailing.com...-clay-bar.html
http://www.glimmerglassdetailing.com/200grmegrpuc.html
Old Apr 17, 2008 | 10:10 AM
Turbo Wax's Avatar
Im not sure if you saw our post on over spray
the car sits in a yard next to a marine paint booth, what you see in the roof is overspray, the entire roof is FULL of it, actually the entire car, or what’s left of it, I was able to remove 99% of it with our bug and oxidation remover, it really did an awesome job, after that I use our swirl remover, pre wax and wax I did use the Porter Cable Machine to finish the job.
Click on Image to enlarge photo
New generation and Technology , environmentally friendly product for dropping & insect grime remover on surface of paint finish.
Purpose:
Turbo Wax Oxidation & Bug remover can be used to quickly and safely remove bonded contaminants, dropping and insect grime from automotive finishes. For automotive paint finishes, this product has the same function and environmentally safety as clay-based stain removers.
The value and benefits:
1)Just use with water, no need to buy other tool or special detergents for rigid stain.
2)Reduce over half time of removing contaminants: Use friendly and it is very easy and quick to remove dropping, insect grime and containments, which bonded on paint finish and only operate with water.
3)Extra value: This product also has same function of clay based and polish when use properly, Will work better than any clay bar when used properly
4)Environmentally friendly: Just use with water and decrease water pollution.
5)Long lifespan of product: At least wash 20 to 35 times in properly use and store.
Old Apr 17, 2008 | 12:32 PM
I've gotta take the car back to the shop to make them fix the a/c anyways. They forgot to re-juice it. I'm gonna try the clay bar first... Thanks for the advice!
SSnRXP
Dec 4, 2015 11:02 PM
bigdogstokes16
Oct 8, 2015 10:28 PM
dasoftest
Sep 29, 2015 02:14 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
QuickSilver_SS
Sep 17, 2015 11:23 AM
