Show & Shine Detailing, washing, waxing, paint care, wax, etc.
Removing badge goo?
Old Nov 11, 2010 | 12:55 PM
YoBaltSS's Avatar
Removing badge goo?
I de-badged my Cobalt about a month and a half ago. Everything came off pretty easily and cleaned up nicely, except for the bow-tie on the trunk. I've had a good chunk of the goo stuck on there since then. It's survived heavy soaping, goo-gone, WD40 and a power-ball waxing.
Any suggestions as to how I get it off?
Old Nov 11, 2010 | 12:56 PM
CobaltVenomSS's Avatar
heat gun
Old Nov 11, 2010 | 01:00 PM
dspeed123's Avatar
Fingernail. Seriously. And I mean that as in for realz, not the smart a$$ version of seriously. Pull it in someplace warm, use a heat gun if you have one and rub it off using a combo of your finger and fingernail.
Old Nov 11, 2010 | 11:10 PM
H3 Proto's Avatar
If this doesn't work, you have a problem.
Old Nov 18, 2010 | 11:34 PM
[10]'s Avatar
I de-badged last week in the cold, well not-so-cold MI air. Blow dryers help A LOT. So does alcohol and an ice scraper.
I held the blow dryer on the black **** and scraped it. It took about 5-7 min. Most of the black **** didn't stick to the emblem, so I had to scrape little-by-little. Just scrape and alk. Repeat. Wash & wax when you're done.
Old Nov 18, 2010 | 11:40 PM
souchak2112's Avatar
Pre kleano is what i used. This might take off the wax but just rewax it afterwards.
Old Nov 18, 2010 | 11:43 PM
TommyP's Avatar
AWD > FWD
I had to rub mine off with the skin of my finger. Burned like hell but it worked perfectly. I also had to do that when I removed the door molding on my old LT sedan. Talk about pain. Glue remover didn't really help with the heavy foam.
Old Nov 18, 2010 | 11:47 PM
JL-KA's Avatar
For me it took (Finger nail) + (a good 20 minutes of picking) + (Turtle Wax 'Bug and Tar' Remover) = Profit
Old Nov 18, 2010 | 11:49 PM
bbrewbaker's Avatar
I used rubbing alcohol
Old Nov 21, 2010 | 10:35 AM
Billy Baldone's Avatar
A good quality bug and tar remover works perfectly.That's what i used
Old Nov 21, 2010 | 11:53 AM
chevysssc's Avatar
adhesive remover. at any autoparts or homedepot
Old Nov 21, 2010 | 12:02 PM
b00sted06ss's Avatar
heat gun/ all purpose cleaner
Old Nov 24, 2010 | 08:41 PM
BooSSted's Avatar
There isn't really an easy way to get it off. All you can really do is heat it and peal it off the best you can.
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
Cptnslo
Sep 24, 2015 09:32 AM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
