Is Scratch X worth it?
So I can't stand the swirl marks in my paint and was gonna go buy some scratch X. Does it really take out swirls like they claim ? and is there another product thats better?
You could also go REALLY REALLY LIGHTLY with some rubbing compound and see what it is.
Most swirls are coming from your washing technique. Use long straight lines, not circular motions. And have another bucket full of clean water and use it to rinse your sponge out before putting more soap on.
Those are pretty bad swirls
Scratch X might help some but being that bad you might be better off just taking to to a quality detail shop and having them buff the car out for you. If that doesn't work any good paint shop should be able to color sand the car out to a show quality finish.
Scratch-X will work here however, applying it by hand is going to take forever
The way to get those swirls out is with a dual-action polisher and either scratch-x or a more agressive polish. Clay-bar and wax will not get rid of these marks at all, only help hide them for a short while.
If you're working by hand, try some poorboys ssr2. Here is a test section on a buick. This is a before/after I did by hand.
Agreed, doing this by machine will yield better results, and more importantly, faster results, lol. Clay is not going to do anything at all. The only thing clay does is remove surface contaminents. Although, if it hasnt been done yet, its worth doing. I've seen some cars come right out of the dealer and needed a lot of clay work from fallout as it sat on the lot, transportation, etc.
For Scratch-X to do any work, you have to really work it in, unlike a wax that you just wipe on and wipe off. Try it again, working small areas at a time.
To really get rid of those swirls (assuming they're not actually deeper scratches, you're most likely going to have to machine polish it with a Dual-Action polisher like the Porter Cable 7424, or a professional rotary polisher, + a good quality polish.
I wouldn't start off with a compound, as it's a bit overkill. Chris(NJ) mentioned Poorboy's SSR line, which is excellent. Another popular over-the-counter line is Meguiar's Mirror Glaze Professional line, namely #80, or the more aggresive #83.
Start with going at it again with Scratch-X. Sometimes technique is everything with the Meguiar's products, I find.
Good luck!
Good luck!
Scratch X is my savior. I've had my Cobalt whacked by everything from car doors to car wash sprayers and it's been able to remove them. The instructions on the packaging are very vague however. I've found it works best to go from side to side against the direction of the scratch with quite a bit of pressure. I couldn't IMAGINE having to do an entire car by hand. My arm would indeed snap off when I was finished.
