Show & Shine Detailing, washing, waxing, paint care, wax, etc.
Tips on cleaning windows
Old Aug 29, 2010 | 04:13 PM
ddawg23213's Avatar
I have a problem where I can not get my windows clean and streak free no matter what I do. I've been using rain x window cleaner and I've tried everything from microfiber towels to newspaper. I just came here looking for any tips you guys may have.
Old Aug 29, 2010 | 07:03 PM
Turbo Wax's Avatar
Have you tried to clay the windows first?
I would try the following steps
1.Wash Window
2.Dried
3.Clay
4.Mix 1part of ammonia to 10 part of water into a spraying bottle, using a damp microfiber towel folded in 8x8 square, spray the window and wipe away, avoid the mix to dry on the window, immediately after wipe away with a dry clean microfiber towel, repeat as needed.
5.Wax your Window
Now you should have a Streak Free Window- This is for windows WITHOUT TINT for the outside the procedure is safe.
I hope this helps
Old Aug 29, 2010 | 07:06 PM
scottydoh's Avatar
Invisible Glass (aerosol) + Newspaper
Old Aug 29, 2010 | 07:12 PM
chris88z24's Avatar
Claybar. Use any cleaner really, spread the solution around with newspaper, then wipe dry with a clean microfiber.
jsscooby's Avatar
I never thought about trying the claybar on the window, but I do see how this could work.
Old Aug 29, 2010 | 07:17 PM
Traviper's Avatar
1.Wash Window
2.Dried
3.Clay
5.Wax your Window
I hope this helps
i heard ammonia can weaken your window, and potentially crack it
Old Aug 29, 2010 | 07:18 PM
exiged's Avatar
Good tips from everyone so far. Also, keep rubbing the same area until it is completely dry. That's most important IMO.
Old Aug 29, 2010 | 07:25 PM
ddawg23213's Avatar
same here, gonna have to try it out.
thanks for all the tips everybody
and as for ammonia weakening the glass, I've heard that too. But I am not so sure it's true.
Old Aug 29, 2010 | 07:34 PM
Turbo Wax's Avatar
I've never heard of that ? That’s why I mentioned the Mix 1 part of ammonia to 10 part of water it is safe.
I do them with our own products and our own system, something that many "Pro Detailer" probably would have a heart attack
Our Body Shop ACC Aluminum and Chrome Cleaner remove’s water spots and creates a clear finish. Simply spray the product onto a clean dry applicator and rub in a circular motion. Then rinse with plenty of water. Avoid letting the product run down onto the painted surface. If this happens, you must rinse right away with water. We have many people using this product for just that problem and they are very happy with the results. I no longer sell this product to the public; people just don’t read the instructions
Rust Marks found on back window as found
Closer View
Done
Old Aug 29, 2010 | 07:41 PM
Billy Baldone's Avatar
Hey Juan you are a good looking man.I'd go camping with you.
Old Aug 29, 2010 | 07:45 PM
Turbo Wax's Avatar
I knew that was a bad idea for that photo! HOWEVER Im 30 pounds lighter now
Old Aug 29, 2010 | 07:50 PM
Sweet,maybe we can both fit in the sleeping bag now
Old Aug 29, 2010 | 08:08 PM
Turbo Wax's Avatar
Old Aug 29, 2010 | 08:11 PM
starkiee06ss/sc's Avatar
rainx isnt good to use on the inside glass it fogs up on the inside
Old Aug 29, 2010 | 08:21 PM
I need some more wax and swirl remover from you,I'll be putting in an order tomorrow sometime.Thanks for all your help on this forum Juan,we reallt do apperciate it.
Old Sep 12, 2010 | 10:42 PM
Blue_Balt's Avatar
This.
The one in the spray bottle works fine too.
Old Sep 13, 2010 | 12:06 AM
br4nd0n187's Avatar
coffee filters no bullshit. i worked for a coffee shop and would clean the windows with coffee filters. leaves absolutely no streaks.
Old Oct 14, 2010 | 03:34 PM
Grishbok's Avatar
I use newspapers as well, anything with small fibers tightly packed do good and polishing clear glass. (not tint). Invisible Glass foam works surprisingly well and doesnt leave a residue.
Old Oct 14, 2010 | 04:08 PM
br4nd0n187's Avatar
old trick when cleaning old works huge windows. use a coffee filter streak freeee no matter what
Old Oct 14, 2010 | 04:35 PM
dayhoff35's Avatar
wait so whipe the window with the filter ive never heard of using newspaper or anything else
Old Oct 14, 2010 | 04:38 PM
BPacak's Avatar
Vtec Rep
yeah so you guys are saying like windex or some window cleaner and either newspaper or coffee filter?
Old Oct 14, 2010 | 04:39 PM
br4nd0n187's Avatar
correct
Old Oct 14, 2010 | 04:41 PM
br4nd0n187's Avatar
i used to clean windows that were like 14ft tall 10 ft wide and always got streaks. and started using coffee filters because i worked at panera bread when i was 16. Nice trick and no streaks
Old Oct 14, 2010 | 04:42 PM
dayhoff35's Avatar
so whipe with a wet filter or dry with one
Old Oct 14, 2010 | 04:49 PM
TommyP's Avatar
AWD > FWD
I've also heard that ammonia will ruin window tint. I always use invisible glass and newspaper. Works amazingly.
