Project OEM
Old 04-04-2017, 01:04 PM
  #51
user 72239's Avatar
all of my **** is HF stuff.
The only thing I've broken from them is a 13mm deep socket, 2 1/4 extensions and a 3/8 to 1/2 converter.
Old 04-04-2017, 01:05 PM
  #52
Originally Posted by Snail_SS
That's true one of the main reasons I try to stay away but I might have to go buy one either way
Use two 4x4s and it will work great, the one 4x4 was a little sketchy due to the engine mount locations. Not to mention if you use two 4x4s with a spreader or spacer you might be able to use them to lift the transmission into place
Old 04-07-2017, 10:38 AM
  #53
user 72239's Avatar
Gotta pull the transmission again because something is still leaking.
Old 04-07-2017, 02:21 PM
  #54
where is it leaking from
Old 04-12-2017, 09:05 PM
  #55
I got that engine brace from harbor freight and it's a little dicey trying to get it mounted on that small weld, but it worked just fine.
Leak- are you sure you got that little bastard clip in right on the clutch pipe. That thing is a mf trying to get back in just right. Sounds like you may need a better helper...
Old 04-12-2017, 09:48 PM
  #56
That had nothing to do with me. I wasn't even there when he did that part but yeah pretty sure that's the part that was leaking.
  #57
user 72239's Avatar
yeah, so the leak was the dist block on top wasn't seated all the way. I had the trans out and figured I'd bleed the TOB to verify no leak. had my buddy push the clutch while I bled it and I heard a pop and the TOB burst lol
Turns out you need to have it installed in the motor so it has something to push against. So I just got the new TOB tonight and installed it etc. Looks good and distro block is installed correctly
Old 04-13-2017, 06:02 AM
  #58
Overextended it?
Maybe you should have had Eric there after all.
Old 04-13-2017, 10:47 AM
  #59
user 72239's Avatar
It made a cool popping noise when I did it. brake fluid shot everywhere in the bell housing lol.
Old 04-13-2017, 11:24 AM
  #60
glad I wasn't there, but it may have saved you a tob
Old 04-13-2017, 08:35 PM
  #61
Ouch
Old 04-24-2017, 11:06 AM
  #62
user 72239's Avatar
Drove her to work today. Need a couple things before its 100%. but im getting around 25 mpg on the DIC so we'll see come fill up time. I'm in love with the clutch already. GMPP is magnificent. the subaru clutch was a PITA to drive in traffic. The clamping force of the pressure plate is more than double that of the GMPP.
ss88 (05-14-2017)
Old 04-24-2017, 12:29 PM
  #63
That picture almost makes her look clean
We'll actually log the car this weekend to see how the trims look. Also if you stay out of WOT you'll get better mileage
Old 04-24-2017, 12:30 PM
  #64
Looking good man
Old 04-24-2017, 12:39 PM
  #65
user 72239's Avatar
I took the pressure washer out after you left and cleaned it with simple green. I also cleaned the interior windows multiple times to get rid of the nicotine.
Old 04-27-2017, 05:23 PM
  #66
Gmpp is a great inexpensive clutch.
Old 05-13-2017, 08:29 PM
  #67
2.2balt's Avatar
Just put a GMPP in mine too. Great clutch. Super easy to daily drive.
Old 05-14-2017, 11:55 AM
  #68
ss88's Avatar
It's back from the grave!
Great Job on the revive
Old 05-15-2017, 11:40 AM
  #69
user 72239's Avatar
installed a low-rise spoiler I got from the u-pull this weekend. I also installed my armrest
Old 05-16-2017, 07:45 AM
  #70
Good find, with Eric.
Old 05-16-2017, 08:51 AM
  #71
Meant to message you, the newest Saab they had was an 03.
Old 05-17-2017, 09:55 PM
  #72
It's ok, thanks for trying. We have one about an hour and a half from us, but they are outrageous on parts. After all it's just a car to get me back and forth from work. While the cobalt sets in the garage.
Old 05-17-2017, 10:10 PM
  #73
I go semi regularly so I'll keep an eye out, the prices are very reasonable since they get a $2 entry fee from everyone.
Hexonxonx
08-25-2016 10:24 PM
Ryan3414
08-17-2016 02:36 PM
jdbaugh1
08-15-2016 04:43 PM
Studer
07-12-2016 03:51 PM
Studer
07-12-2016 03:16 PM
Quick Reply: Project OEM
