blacklight
Old Apr 7, 2006 | 01:28 AM
CobaltCowboy's Avatar
blacklight
hate taking pictures of black materials in bad lighting. it just never works out but i felt compelled to share this with you all.
what do ya think?
Old Apr 7, 2006 | 01:34 AM
eazyasone23's Avatar
wow that looks really nice on a black car. is that gloss black?
Old Apr 7, 2006 | 01:35 AM
CleanNFun's Avatar
I like how clean your making it . Better be clean as well for the next meet!!
Old Apr 7, 2006 | 01:39 AM
djpatrick35's Avatar
That looks really good, Cowboy. What has gotten into you these days? At the rate you're upgrading, I think your Cobalt will be self-aware by the end of the year!
yeah i clear coated the paint. i want a new set to do it right. had a little issue with the glue resetting and touching the bezel.
Old Apr 7, 2006 | 11:04 AM
MachiBLue's Avatar
That look nice and clean.. Got any day pics of the whole front?
Old Apr 7, 2006 | 12:12 PM
tiny's Avatar
if you buy a new set, ill buy your old ones off you
Old Apr 7, 2006 | 12:14 PM
R33P3R007's Avatar
360 L337 User
looks good
Old Apr 7, 2006 | 12:20 PM
HackAbuse's Avatar
bitchin
Old Apr 7, 2006 | 12:25 PM
why, yes i do have day pics. i was so excited last night i had to tease myself with a coupla pics.
looks good with the blacked out grill, huh?
Old Apr 7, 2006 | 12:27 PM
GSoccer24's Avatar
looking really good man
Old Apr 7, 2006 | 12:29 PM
kadumel's Avatar
Hmm quick question - what did you reseal the lights with? and how long did it take? also what did you use to clean the surface where the old sealant was?
Old Apr 7, 2006 | 01:10 PM
i resealed the lights with Permatex black scilicone adhesive sealent. i used black in case it got on the bezel.
took about 5 hours total per light.
First - heat oven to 200 and bake the housing (all lights removed) for 25 min.
Second - pull housing apart. with my bake method it pulls straight apart no tools needed.
Third - sand all the chrome paint off. if you dont your **** will flake eventually.
Fourth - prime the bezel with paint adhesive, 2 coats. Dupli-color makes this stuff.
Fifth - paint your body color or black, again at least 2 coats. Dupli-color makes all the gm colors.
Sixth - Clear Coat with dupli-color, 3 coats. let the clear coat set before you touch it.
Seventh - heat oven to 200 and rebake the painted housing and lens seperately but at the same time being carefull not to get adhesive on the fresh paint.
Eight - pipe the new sealeant into the track and press the lens and housing together, tightly.
you're done.
i did not clean the old gray stuff off the housing back. it shows through a little and does not match my black beauty. which is the reason i want to redue this project with a new set of lights. i found that 3m makes a product that removes the adhesive. i used it during my project but did not have enough to completely clean my light housings.
hope this helps.
Old Apr 7, 2006 | 01:39 PM
HackAbuse's Avatar
Get silverstars for your turn markers, it looks alot better!
Old Apr 7, 2006 | 02:33 PM
didnt know they made the turn signals. so whats the difference between the two. they would still be yellow right?
Old Apr 7, 2006 | 02:44 PM
HackAbuse's Avatar
theyre yellow when on and bluish when off
Old Apr 7, 2006 | 02:46 PM
just called pepboys. picking up a set only 10 bucks and its gonna look hot. thanks dawg
Old Apr 7, 2006 | 03:12 PM
Mercury's Avatar
That is the first 4 door I have seen with painted lamps, looks good!
Old Apr 7, 2006 | 03:40 PM
hey merc you notice the black grill?
Old Apr 7, 2006 | 03:47 PM
wikkymaster's Avatar
i ahve the silverstar corner lights in mine, you can see in my sig
Old Apr 7, 2006 | 04:42 PM
GSoccer24's Avatar
or you can get the silver xtremes from our forum vendor vision bulbs and instead of having a bluish bulb in there, you can have a silver one in there that blends with the housing.
you can see it in the top of the black part of my old headlights. they look a bit darker because i went with full black up there
Old Apr 7, 2006 | 07:16 PM
MachiBLue's Avatar
Those are some nice pics.. I wish I had the time to do something like that..
Old Apr 8, 2006 | 02:51 AM
already picked up the silverstars. they'll burn out in like six months and then i'll get the vision.
Old Dec 19, 2006 | 01:31 AM
HunterKiller89's Avatar
bumpin this one too guys...
MyBalt10
Feb 7, 2013 11:44 PM
g_muska
Sep 8, 2009 02:37 PM
jasonaudio
38
Mar 16, 2008 05:33 PM
