For Sale AIS Stage 1 Water/Meth Kit and TB Spacer
Old Sep 8, 2010 | 01:25 AM
RooTBeeR's Avatar
Anyone looking for a meth kit? I'm not gonna use it it anymore, never installed on my car, but it is used(barely) Junior(euthanasia [on ss.net]) had it installed on one of his mustang's, got it all setup to work and then took it off the car. It's an AIS stage 1 kit with an M10(10gph) nozzle with the "old" smaller 1.5(might be only 1gallon, pretty sure it's 1.5 tho) gallon tank, looking for $200 Shipped(48 States, international extra) OBO
also have a TB Spacer LINK OTTP TB spacer with 1/8" npt tap for meth or nitrous (had it on the car for about 1000miles never sprayed anything through it tho, payed $78.99 for it less than a year ago) will let it go for $50 Shipped(48 States, international extra) OBO
1 x Throttle Body Spacer With 1/8" NPT Tap () = $78.99
Throttle Body Fitted On Vehicle Stock +
heres vids of it working, get a pic up later
Meth kit with M10(10gph) nozzle Meth kit with M10(10gph) nozzle
PayPal Only, Thanks
Originally Posted by RooTBeeR
yes you'll need a tune, a smaller nozzle is recommended(you wont need bigger than a M5 {5GPH} nozzle), some where to mount the nozzle(throttle body spacer and/or supercharger spacer are the easiest)...
This is off the AIS website(what one of their brand new kits includes) The parts marked in bold are what the kit was sold to me with/what i am selling. never installed or used it myself, but i did hook it up to power and turned boost switch all the way down and it worked.
System Contents Include:
Custom molded 3 gallon tank designed specifically for our pump I have the older kit that has the smaller 1.5 gal tank
All new 250 psi pump with EPDM seals for use with 100% methanol I believe(due to being the older kit) this is a 150psi pump
1-25 psi adjustable boost activated switch
Nickel plated threaded injector holder
Interchangeable injector sized to application The nozzle I have for it is a M10(10gph) which is too big for a cobalt, but can be easily changed
Heavy duty one-way check valve
20 ft of black high pressure vacuum tubing
*I have about 50' vacuum/water-meth line
20 ft of black high pressure water methanol tubing
20 ft of electrical wire
LED activation light
Grounding wire with grounding screw and terminal
Vacuum tee fitting
Two rubber grommets
Water resistant fuse holder with fuse
Four butt connectors
10 each 8" zip ties (large)
5 each 4" zip ties (small)
Two black anodized aluminum tank straps
Detailed instructions with pictures
AIS sticker
so you'll need a fuse/fuse holder, wire, connectors...Heres the best install instructions i could find, this is for a cooling mist kit, but they all install pretty similarl http://www.coolingmist.com/instructions/CMS1deluxe.pdf
and heres a how to on installing an activation light to ur kit so u know when its on https://www.cobaltss.net/forums/how-...system-123603/
Old Sep 8, 2010 | 10:58 PM
RooTBeeR's Avatar
Night Bump!
Old Sep 9, 2010 | 12:42 AM
b00sted06ss's Avatar
stupid question but was there any noticeable difference with the tb spacer?
Old Sep 9, 2010 | 12:51 AM
RooTBeeR's Avatar
not that i noticed no, it has the tap for a meth nozzle tho...with the blower on the car the TB spacer really doesnt have the same effect as it might on an N/A engine i dont think lol
Old Sep 11, 2010 | 04:27 PM
RooTBeeR's Avatar
Bump for anyone else?
Old Sep 17, 2010 | 02:30 PM
RooTBeeR's Avatar
still for sale, anyone interested? gimme a price...
Old Sep 17, 2010 | 04:15 PM
clough1022's Avatar
If I wanted cooler intake temps. Could I run meth before going through with the stage 2 setup?
Old Sep 18, 2010 | 09:08 PM
RooTBeeR's Avatar
the meth/water mix cools the intake charge by being sprayed in the the intake air charge itself(after the MAF sensor). it is totally seperate from the intercooler system for the blower which is a coolant style system.
Old Sep 21, 2010 | 11:23 PM
RooTBeeR's Avatar
Prices updated.
Old Sep 22, 2010 | 10:43 AM
red balt's Avatar
interested in tb spacer but need to get paid! haha
Old Sep 22, 2010 | 02:46 PM
RooTBeeR's Avatar
alright, let me know
Old Sep 22, 2010 | 06:32 PM
BlueSS/SC's Avatar
How much to ship to canada? I know im ******* far!
k1b5k6
Old Sep 22, 2010 | 09:51 PM
RooTBeeR's Avatar
k1b5k6
for the Meth kit?
cheapest i can find is ~$35-40(usd)
Old Sep 22, 2010 | 10:07 PM
stoon_cobalt_colby's Avatar
pm'd
Old Sep 23, 2010 | 12:07 AM
RooTBeeR's Avatar
Replied
Old Sep 26, 2010 | 12:40 PM
RooTBeeR's Avatar
just throw me a price...
Old Sep 27, 2010 | 09:13 AM
05Blackss.sc's Avatar
So do you need a tune to run this...what all is needed to install/have working properly
Old Sep 27, 2010 | 09:41 AM
RooTBeeR's Avatar
Vacuum tee fitting
Two rubber grommets
AIS sticker
Old Sep 27, 2010 | 12:56 PM
damn....lol
Old Sep 27, 2010 | 03:08 PM
RooTBeeR's Avatar
damn....lol
damn what? i have all the major/expensive parts. wire and connectors are cheap and you can get then at a lot of stores
Old Sep 27, 2010 | 03:52 PM
SRTCobaltSS's Avatar
125. I'll pick it up.
Old Sep 27, 2010 | 05:23 PM
BlueSS/SC's Avatar
^^ lol
Old Sep 28, 2010 | 05:26 AM
^^ You're just jealous cause YOU can't pick it up! Lol! My offer still stands. Or 200 if you help me install it. Laugh at that blueSS/SC! Lol!
Old Sep 28, 2010 | 09:05 AM
oh yeah dont get me wrong...this is a hell of a deal...i just dunno if i can afford this and the tune and the other things i need....ill let you know after i find prices for a tune! GLWS
Bump!
Old Sep 28, 2010 | 09:33 AM
RooTBeeR's Avatar
lol oh gotya.thanks
