Flow calculation for some LSJ parts.
Old Jul 18, 2007 | 02:46 PM
Jmc007's Avatar
Hi ! Here are my flow calculation for some LSJ engine parts :
ADDED COMMENT : These flow numbers are calculated at ambiant air temperature AND pressure.
Stock Throttle Body (67 mm) : 625 CFM.
EDITED : Stock Head : One intake port : 250 CFM @ stock 0,395" valve lift. One exhaust port : 145 CFM @ stock 0,395" valve lift. Stock head is said by GM to be efficient up to 275 WHP; it is clearly possible to make more WHP than that, but in a unefficient way (several HP losses caused by heat and restriction).
Stock Exhaust manifold ("Header") : 425 CFM.
Stock Downipe (DP) with cat : Plus or minus 370 CFM or less.
Stock Cat-back Exhaust (2,5" inlet to 2,25" outlet with stock muffler) : 300 CFM.
Now here are some replacement parts :
GMPP Exhaust manifold ("Header") : (30 more CFM than stock) : 455 CFM.
Shorty or long tube Header with 1,75" primaries and 2,5" outlet : at least 500 CFM.
Shorty or long tube Header with 1,75" primaries and 3" outlet : at least 725 CFM.
Shorty header with 1,5" primaries and 2" outlet : Waay not enough, who cares LOL.
Stock DP w/o cat : 425 CFM.
2,5" DP with VERY HIGH FLOW cat : plus or minus 450 CFM.
2,5" DP w/o cat : 500 CFM.
2,75" DP with VERY HIGH FLOW cat : plus or minus 475 CFM.
2,75" DP w/o cat : 600 CFM.
3" DP with VERY HIGH FLOW cat : plus or minus 500 CFM.
3" DP w/o cat : 725 CFM.
Stock catback with only the rear muffler replaced (the last portion is still in 2,25" tubing) : 350 CFM.
Stock catback with last portion replaced for 2,5" tubing and straight through muffler : 450 CFM.
2,5" catback : From 450 to 500 CFM (must be a straight through muffler).
2,75" catback : From 550 to 600 CFM (must be a straight through muffler).
3" catback : From 650 to 725 CFM (must be a straight through muffler).
Hope this can help ...
Regards )
Last edited by Jmc007; Sep 4, 2007 at 10:23 PM. Reason: EDITED Stock Head Info and added comment.
Old Jul 18, 2007 | 03:17 PM
Area47's Avatar
Rent me! per hour
you kick ass.
that is all
Old Jul 18, 2007 | 04:46 PM
CobaltSS313's Avatar
wow thats awesome thanks
+1 rep
Old Jul 18, 2007 | 04:48 PM
shawns94's Avatar
Great info!!
Old Jul 18, 2007 | 04:50 PM
Omega_5's Avatar
Very nice...
Now lets account for some BOOST!
Old Jul 18, 2007 | 04:51 PM
BlackSS/SC's Avatar
WOW! Nice info! How did you get all that?
Old Jul 18, 2007 | 05:41 PM
Omega_5's Avatar
I'm going to assume that he used basic flow dynamic calculations....
Pretty time consuming if your doing it by hand....
Old Jul 18, 2007 | 06:00 PM
Area47's Avatar
Rent me! per hour
whats the stock intake manifold flow?
just out of curiousity
Old Jul 18, 2007 | 06:27 PM
Jmc007's Avatar
The stock intake manifold flow is more limited by the air filter itself, but i dunno what's that flow ...
Old Jul 18, 2007 | 06:53 PM
Area47's Avatar
Rent me! per hour
hmmm, good point. i'll dig something up
Old Jul 18, 2007 | 07:05 PM
ggarcia86's Avatar
good info indeed
06blackg85ss's Avatar
good job man
Old Jul 18, 2007 | 07:15 PM
06black's Avatar
If you were to factor out the air filter, and even an intake....what would be the upper limit of air flow thro the intake manifold? I assume as this point the lamnova(sp?) cores themselves become the restriction....
shoot me a number or at least an educated guess....
and yea....wicked awesome post!
Old Jul 18, 2007 | 07:16 PM
RedlineBrian's Avatar
+1 for this one.
Old Jul 18, 2007 | 07:20 PM
Area47's Avatar
Rent me! per hour
k&n number ru-4990
for those of us who have a k&n intake system
some quick specs.
Base Outside Diameter: 6 in (152 mm)
Flange Inside Diameter: 3 in (76 mm)
Flange Length: 1.875 in (48 mm)
Flange Type: Centered
Height: 5.563 in (141 mm)
Top Outside Diameter: 5 in (127 mm)
i'll give k&n a call tomorrow see if i can't dig up some cfm info on these little guys
Old Jul 18, 2007 | 07:21 PM
RoelSS's Avatar
Great Job
Old Jul 18, 2007 | 07:27 PM
Blown 4-banger's Avatar
EVERY part of my exhaust system flows 725 CFM
Old Jul 18, 2007 | 07:30 PM
Area47's Avatar
Rent me! per hour
what header?
Old Jul 19, 2007 | 05:11 AM
Jmc007's Avatar
Originally Posted by Area47
k&n number ru-4990
some quick specs.
I'm pretty damn sure that this K&N filter flows way more itself than the stock airbox. But i was talking more about the stock air filter cfm, which is so dense and packed.
Old Jul 19, 2007 | 05:34 AM
SilverSS/SC's Avatar
great job , good info man
Old Jul 19, 2007 | 11:34 AM
Area47's Avatar
Rent me! per hour
ahhhhhhhhh, now i see
kudo's good sir!
Old Jul 20, 2007 | 09:06 AM
RoelSS's Avatar
jmc007, just noticed one thing, how does the stock manifold (1.75" D shaped outlet, flow equal to the 2" catless downpipe?
https://www.zzperformance.com/products_img/543_3.jpg
Just wondering...............
Old Jul 20, 2007 | 09:09 AM
CTCOBALTSSS's Avatar
Awsome in fo man. Nice find.
Old Jul 28, 2007 | 12:13 AM
Jmc007's Avatar
If you look at the caliper on the picture, it doesn't seem to touch on both sides. Also, the manifold collector isn't long, so it's less rectrictive than a long downpipe of the "same" diameter.
Old Jul 31, 2007 | 02:45 PM
ebristol's Avatar
This info really needs to be sticky'd.
There are lot of misconceptions about the LSJ exhaust that could be cleared up with this thread.
