Please Help Keys stuck in ignition
Old Oct 1, 2005 | 03:04 AM
KeFkA-XIII's Avatar
Hey i know this doesnt belong here but i need help has anyone ever had there key stuck in the ignition and not able to get them out? I cant figure it out for the life of me i tried to drive it around, put it in neutral and everything if anyone can help please i cant leave them in the car lol
Old Oct 1, 2005 | 04:10 AM
mi6_'s Avatar
Is it a manual or an automatic Cobalt?
Sometimes on the autos, they won't let you take the key out unless it is in park as a safety feature. Make sure it is going into park properly. If it is a manual, there is sometimes a little button near the ignition that needs to be depressed to release the key from the tumblers. I don't think the Cobalt has this feature though.
Thats all I can think of. I haven't ever had that happen to me in any vehicle, so I'm not really sure what could be causing this.
Old Oct 1, 2005 | 06:02 AM
JimmiLS05's Avatar
try turning the steering wheel until it locks or keys come out maybe?
Old Oct 1, 2005 | 10:30 AM
plyboy-illest's Avatar
same things happens to my sister cobalt LS when you turn the car off put it into park the key gets stuck 90 % of the time u got to play around with it and sooner or later it comes out....
Old Oct 1, 2005 | 10:35 AM
badg1rl's Avatar
go back to the dealership and get a new ignition cylinder...that **** will only get worse. i have seen soooo many cars come in with that problem.
Old Oct 1, 2005 | 10:47 AM
giddings75's Avatar
there is a small rubber thing right under your steering wheel that comes off and you should be able to stick your finger up there and realse the key some how, that is what it says in the owners manual.
Old Oct 1, 2005 | 11:12 AM
c7015's Avatar
this may help you
http://www.danerd.com/Show.php?vid=1086
Edit ..well not really but I just wanted to post it since I have never had my keys stuck in the ignition
Old Oct 1, 2005 | 11:25 AM
mafsu's Avatar
Had this problem in my old grand am. There should be a small plastic or rubber plug on the bottom of the steering column. if you remove it you can stick your finger or a pen into the hole and press the button there. It will release your key. Sounds like the problem is a bad solenoid that is activated when the car is shifted into park allowing the key to be removed. The button manually releases the lock on the key.
Old Oct 1, 2005 | 12:21 PM
T Dawg's Avatar
Originally Posted by c7015
this may help you
I have been having a crappy week and that was fing funny as hell, thank you for posting it.
Old Oct 1, 2005 | 01:18 PM
chevytech329's Avatar
If your car is an automatic, make sure its all the way in park (yea i know sounds dumb) and make sure the small knob that u push to take itout of park is pulled out and not
still partially pushed in. I have seen about 5 of these at work. All of them have been
because of beverage spilled in the shifter.
fyi
Jeff
2005 SS/SC
Old Oct 1, 2005 | 01:46 PM
KeFkA-XIII's Avatar
Sadly
Nothing worked and i took it to the dealership and they were too busy to fix it and now i have to wait till monday this is just my luck lol the whole problem is not that it doesnt come out it doesnt even make the final click down to where u should be able to take it out. Its almost like the steering wheel isnt locking so its not letting me get the key down.
Old Oct 1, 2005 | 02:05 PM
mikekoz's Avatar
yikes, that really sucks.
Old Oct 1, 2005 | 02:18 PM
Jarmez258's Avatar
My Cobalt is doing the same thing (automatic). I called the dealer, and they think it may be a bad switch, which is activating the torque lock. I am taking it in next week to get fixed.
Old Oct 1, 2005 | 04:36 PM
Sarbae's Avatar
Something similar happened to my automatic '92 S-10 Blazer not too long ago when I asked my Salvadorian friend to turn it on for me. The key was stuck in the cylinder, and the car wouldn't turn off, so I had to drive it home, pull the wires from the coil to the distributor, remove the steering wheel (that was a pain, I had to rent a tool from Pep Boys), and replace the key cylinder and keys (GM shop had a set in stock for around $40, bought it there, installed it, then bought one online for $16 and returned that one to GM for a full refund). Unfortunately, I broke the connection for my bad-ass horn in the process, so I wired the beast to a switch by my feet!
Good luck. Removing the steering wheel was the hardest part (had the Salvadorian idiot help out), but you should be able to figure it out.
Old Oct 1, 2005 | 09:16 PM
c7015's Avatar
Serriously Call Blondestar >>>>>>>
lol
Old Oct 1, 2005 | 09:47 PM
KeFkA-XIII's Avatar
at least im not the only one with the problem
Old Oct 2, 2005 | 10:17 AM
jesslikes2speed's Avatar
sometimes i feel as if my key is going to be stuck, but it thankfully always manages to come out. i hope i didn't just jinx myself!!!
Old Oct 2, 2005 | 07:07 PM
s113's Avatar
I had a problem with the key getting stuck in my former 2004 Malibu LT on cold mornings last fall, unless I used the remote start to warm it up. First, I took it to the dealership where I bought it, and they couldn't figure out what the problem was (wasn't sure if it was electrical connections not being made, or simply the cold weather causing problems). I took it to another dealer and they found a bulletin on the issue, and they fixed it.
turbochargedss2012
Sep 20, 2023 12:17 PM
satisfied
Oct 19, 2015 12:35 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
