Installing stereo
Old Oct 16, 2005 | 09:17 PM
hardtocope's Avatar
Installing stereo
How does the factory head unit come out of the car? Does the plastic peices just pull off? Also will I need a capacitor if I run one jl w3v2 with a 300 watt amp?
Old Oct 16, 2005 | 10:45 PM
MoMo789's Avatar
the side moldings around the headunit will come off the piece above the glove box will come off and the one for the information buttons will 2. and all u gotta do is unscrew the stock head unit and put your headunit and insert in. cuz the plastic piece are in there by little gold clips. and u dun need a capacitor unless your pushing a 1000 watt amp.
Old Oct 16, 2005 | 10:55 PM
hardtocope's Avatar
Wires
Where should i run the rca wires and turn on wire?
Old Oct 16, 2005 | 11:05 PM
MoMo789's Avatar
run it behind the console and under the glove box. then run it from there under the paneling above the floor carpet . then run it under the arm rest for the back then trough there into the back seat and then into the back.
But 1 question do u have a coupe or sedan??
Old Oct 17, 2005 | 12:08 AM
hardtocope's Avatar
stereo
I have a coupe. Thanks for your help
Old Oct 17, 2005 | 12:11 AM
MoMo789's Avatar
me 2
Old Oct 17, 2005 | 12:15 AM
Clmbngfrk18's Avatar
yeah not need for a cap might still have some light dimmin i get in with my 500\1 not huge just need a bat upgrade
Old Oct 17, 2005 | 08:42 AM
slowbalt's Avatar
light dimming is a bad sign. It means your amp or amps are pulling so much power that your bat. cant give enough power to all the other functions. If you have this get a cap or you will be replacing your altinator.
Old Oct 17, 2005 | 06:12 PM
ORT's Avatar
ORT
Or upgrade the big 3....I still think caps aren't worth the money......so pointless. But thats just me.
Old Oct 17, 2005 | 06:17 PM
VaMP's Avatar
You should know that your radio will only work in your car. It has to register with the cars main computer and if your vin number doesn't match up, you can't use the stereo system.
Old Oct 17, 2005 | 09:46 PM
02blazerx's Avatar
^^^There are ways to disable theftlock on all gm radios so that they can work in other gm cars.
Old Oct 18, 2005 | 10:05 AM
hardtocope's Avatar
aftermarket radio
so are you saying if i install a aftermarket radio it won't work in my car cause of the computer?
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
